No crank, No Start
  • BigMoneyMike2020
  • BigMoneyMike2020's Avatar Topic Author
2 years 6 months ago #65119 by BigMoneyMike2020
No crank, No Start was created by BigMoneyMike2020
Hello, I am working on a 2016 Jeep Cherokee that has a no crank. When you turn the key the radio does not come on, Nothing does. I replaced the Ignition switch which is called Ignition Node Module. From there I have a Wht/ Lt Grn wire and Vio/Brn wire that goes to Radio Frequency Hub Module. From there I have a Dk/Blue Wire and a Yellow wire that is Can+ and Can-  from there those Can+ and Can- wires goes to the Star Can C Body Connector. I scanned the codes the only code that was there was u0101 c2 can bus fault. Ever since I tried to clear them, My scan tool no longer communicated with the car. I then went ahead and replaced the ignition switch (Ignition Node Module) and Im still STUCK. Any ideas?
2016 Jeep Cherokee 75th anniversary edition 2.4L
