Adding pictures is a two stage process after you click "Attachments" and drag and drop your picture in you then have to click "Insert" or "Insert All" before clicking "Submit"
The other problem that occurs is a picture particular those taken with a mobilephone usually exceed the picture size limit I use the Export function on Google Picasa but Google Picasa is no longer available.
Last edit: 9 years 3 months ago by Andy.MacFadyen.
Thanks for the instructions. but every time I press the insert button to add a picture it adds words to the message box describing the attachment and not a picture.
moggie4312 wrote: Thanks for the instructions. but every time I press the insert button to add a picture it adds words to the message box describing the attachment and not a picture.
That's OK - when you Submit the post, the text will be replaced by the actual picture. Kinda a weird system, but you get used to it after a few uses.
