1997 chevy misfires at high speeds
  • Gageb562
  • Gageb562's Avatar Topic Author
2 years 7 months ago #64771 by Gageb562
1997 chevy misfires at high speeds was created by Gageb562
I have a mystery misfire on my 1997 2 door tahoe witht the 5.7l vortec v8. It drives great on the streets, no hesitation in the throttle, lots of power and no signs of a misfire. As soon as I get up to 60+ mph on the freeway, it will start misfiring on cylinder 6, shaking the whole truck and throws a P0306 and P0300 code. It will then slip the TC so I can't get it into full lock or else it will just keep misfiring under load (especially when towing). I have a TopDon scanner tool that I used to set the camshaft posting retard when I installed a new distributor ( gear was pretty worn). I've also replaced cap and rotor 3 times, ignition coil 2 times, ignition coil control module 2 times, plug wires, all 8 spark plugs, fuel filter, crankshaft position sensor, transmission speed sensor, and both upstream 02 sensors. It still rides great on the streets, but nothing made my misfire on cylinder 6 at 60+ mph go away. When I tested the fuel pressure I get about 55 psi KOEO and about 48 psi at idle. I thought the fuel pump was okay because when I'm driving through gears the psi is a constant 60 psi, even when it's misfiring. I'm thinking about just replacing the fuel pump but I'm tired of firing the parts cannon at my beautiful truck. Oh yeah, MAF and O2 sensors all check out and fuel trims are normal and I upgraded the injector to the electronic spider about 5 years ago. Any help would be much appreciated.
2 years 7 months ago #64782 by bills4065
Replied by bills4065 on topic 1997 chevy misfires at high speeds
I did not see if you have done a compression check yet on the engine.
  • Gageb562
2 years 7 months ago #64783 by Gageb562
Replied by Gageb562 on topic 1997 chevy misfires at high speeds
I have only done a compression test on cylinder 6 and I got 155 psi. I will do all 8 cylinders tomorrow and I'll let you know what I get.
2 years 7 months ago #64798 by Lupe
Replied by Lupe on topic 1997 chevy misfires at high speeds
you said the gear on distributor was worn , might want to look into hole and check your cam gear that it sit in .
good luck
2 years 7 months ago #64804 by ontheriver
Replied by ontheriver on topic 1997 chevy misfires at high speeds
What about a inspection of the valve springs, might have a cracked/broken one on that cylinder?
  • Gageb562
2 years 7 months ago #64805 by Gageb562
I pulled the vavle cover off just to see, and everything looked good.
  • Gageb562
2 years 7 months ago #64806 by Gageb562
Compression test (dry):
1: 190 psi. 2: 175 psi
3: 190 psi. 4: 175 psi
5: 175 psi. 6: 175 psi
7: 195 psi. 8: 150 psi
2 years 7 months ago #64807 by Hardtopdr2
Replied by Hardtopdr2 on topic 1997 chevy misfires at high speeds
You will want to test valve spring tension and look at push rod ends for that cylinder. this will determine if you have a valve floating from weak valve springs or a collapsing lifter\bent pushrod. also check and readjust rocker arms.
