Injector driver how to diagnose
  • Jclagg82
  • Jclagg82's Avatar Topic Author
2 years 7 months ago #64770 by Jclagg82
Injector driver how to diagnose was created by Jclagg82
I'm working on a 2011 Ram 1500 with a 5.7 Hemi. At all speeds below 70 mph it runs fine but above that it shuts down cylinder 5 but once it gets below 65 it comes back and runs perfectly. I have changed the injector and coil and plugs, but no change. I can see on scan data the injector has no pulse with after 70 mph.
2 years 7 months ago #64774 by Tyler
Replied by Tyler on topic Injector driver how to diagnose
What fault codes are you seeing, specifically?
On a hunch, I'd suspect that the loss of injector pulse isn't the problem, it's a symptom. The PCM is probably taking injector pulse away from #5 because it detected a misfire and shut the injector down for catalyst protection purposes.
Being a Hemi, I'd start with cranking and running compression on #5. Compare both to a known good cylinder.
