Signal wire testing with LED.
  • bslater
  • bslater's Avatar Topic Author
2 years 8 months ago - 2 years 8 months ago #64561 by bslater
Signal wire testing with LED. was created by bslater
Hey all, I have a Kia Sedona 2002 v6 that has been acting strange, and I have no been able to figure it out (however I think I am close.) It's a no spark no start. It gets gas, and compression is good. The ignition coils are 3 wire and all have 12v going to them, they have ground, and they have a signal (used a led as that is all i have). However, I noticed the wires to the coils are pretty bad, and when I measure the signal with led light; Coil 1 has a very faint pulse as it should be. Coil 2 and 3 the LED light flashes Bright on the signal pulse. Which I assume there crossed wires somewhere?
Last edit: 2 years 8 months ago by bslater.
2 years 8 months ago #64568 by Noah
Replied by Noah on topic Signal wire testing with LED.
You're going to need to provide the year and engine for anyone to be able to help you efficiently.
Are these 3 or 2 wire coils?
Your description makes it sound like 3. How are you checking spark?
A 3 wire coil will make spark if it has power ground and control.
2 years 7 months ago #64602 by Lupe
Replied by Lupe on topic Signal wire testing with LED.
so it cranks ? does it have a R P M as u crank on the dash ? as noah asked more info please , what have you done to it , old 2002 , has it been tuned or coils checked or new , any codes ? thanks
