1992 Ford F150 will not start.
- dezman007
2 years 9 months ago #64111
by dezman007
1992 Ford F150 will not start. was created by dezman007
Hello there,
Truck ran strong 3 weeks ago when used. This time it only started twice, once after several turns of the key. Then the next morning fired right up once. Nothing since. Strong, smell of gas when trying to start. Troubleshooting results are no gas leaks present, no gas coming from gas regulator, IAC sensor has 7 ohms. Fuel pump changed 1 year ago. Going to purchase code scanner in near future. Any thoughts on this issue. Thanks David
2 years 9 months ago #64128
Replied by Chad on topic 1992 Ford F150 will not start.
Have you checked for spark?
- dezman007
2 years 9 months ago #64131
by dezman007
Replied by dezman007 on topic 1992 Ford F150 will not start.
I knew I forgot some info, Yes spark is strong. This truck has a history of fuel issue it seems. It's strange the other morning it kicked right over. It's a simple fix, just have to find it.
- dezman007
2 years 9 months ago #64132
by dezman007
I checked for spark at spark plug. Nothing prior in firing system.
- dezman007
2 years 9 months ago #64138
by dezman007
I've installed a permanent fuel pressure gauge awhile back. I'm getting a constant 40 psi, correction the IAC sensor is measuring at 9 ohms.
- JChanz!!
2 years 9 months ago #64178
by JChanz!!
Replied by JChanz!! on topic 1992 Ford F150 will not start.
the fact that you smell fuel leads me to think that you could have a leaking injector. Check the static fuel pressure to see if it holds pressure without dropping down.
- dezman007
2 years 9 months ago #64179
by dezman007
As stated in previous comments no leaks present, psi is a constant 40 psi. The ECM is at a place of business being tested and repaired. There are indications that capacitors have leaked.
