please help . voltage drop test on alt and batt.
  • MechanicalInclanation669
  • MechanicalInclanation669's Avatar Topic Author
2 years 9 months ago - 2 years 9 months ago #64100 by MechanicalInclanation669
please help . voltage drop test on alt and batt. was created by MechanicalInclanation669
so i've been doing a lot of research on voltage drop and used on a 09 tahoe and im wondering if anyone can suggest a reason for my findings.
while running and all avalible loads on, i had
14v on alt. pos and neg connections
14v on battery pos and neg connections
and the part im not understanding is
50v for alt ground(mount) to batt neg.
250v on alt pos to battery pos
adding a 0gage wire between the block and batt. neg lowered the 50v to 15v
(i work in an audio/ remote start shop and this came in for an different issue and was told about what another shop had done and charged him so after i did what he was here for, i did this just out of curiosity thinking i would find normal or non-problematic readings)
where im confused is how im getting such high numbers for - to -  and from + to +
Last edit: 2 years 9 months ago by MechanicalInclanation669. Reason: new title to hopefully get a response
2 years 9 months ago #64102 by Chad
Can you post a pic of your meter?
My best guess is that your meter is auto-scaling.  Are you sure it isn't reading milli-volts, mV?
2 years 9 months ago #64137 by MechanicalInclanation669
Replied by MechanicalInclanation669 on topic please help . voltage drop test on alt and batt.
thanks thats most likely the case, im new to asking questions on the interwebs so i did not think to get photos. will keep in mind for next time. thanks again for the response
