No can communication
  • Gvhardware1
  • Gvhardware1's Avatar Topic Author
2 years 10 months ago #63875 by Gvhardware1
No can communication was created by Gvhardware1
08 gmc sierra 3500 no can gm high speed communication network has gateway module
  • Gvhardware1
2 years 10 months ago #63876 by Gvhardware1
Replied by Gvhardware1 on topic No can communication
Any help is appreciated this truck has been through 3 different shops they made a mess of wiring got most back to stock but still no can bus communication
  • Gvhardware1
2 years 10 months ago #63877 by Gvhardware1
This is a 6.6 duramx 4wd truck
2 years 10 months ago #63879 by Paul P.
Replied by Paul P. on topic No can communication
1.  With the batteries disconnected, how many Ohms are on Pins 6,14 at the DLC?
2.  Will ANY module on the high speed talk to a scan tool?
3.  Do you have a scope?
Never stop Learning.
  • Gvhardware1
2 years 10 months ago #63898 by Gvhardware1
35 mega ohm between 6 and 14 with gateway module disconnected drops to 5 mega ohms and no high speed communication at all on any module on the network tested resistor back by tbcm 120ohm checked internal pcm resistance 122ohm and yes have a scope
2 years 10 months ago #63900 by Paul P.
Your Canbus is open circuit.
Im looking at Alldata for you vehicle and I do not see a gateway module, perhaps you refer to the BCM as the gateway?
You are going to need a proper wiring diagram to get anywhere with this.
  • Gvhardware1
2 years 9 months ago #63915 by Gvhardware1
It has a gateway module havent pulled out of dash
  • Gvhardware1
2 years 9 months ago #63916 by Gvhardware1
Have pulled it from dash
2 years 9 months ago - 2 years 9 months ago #63919 by Paul P.
Have to get you. a wiring diagram, wont work from my phone atm.
Last edit: 2 years 9 months ago by Paul P..
2 years 9 months ago #63932 by Noah
Replied by Noah on topic No can communication
This browser does not support PDFs. Please download the PDF to view it: Download PDF
The following user(s) said Thank You: Chad, Paul P.
  • Gvhardware1
2 years 2 months ago #66380 by Gvhardware1
Figure I'd close this question as stated truck was a mess put all wires in the can circuit back to stock wiring configuration found pins damaged on bcm pcm gpcm ebcm tbc from using improper tools to test connections ends at connectors after repairing those terminals many discontinued from gm particularly the gpcm used used terminals out of connectors from salvage yard 😀 then once can communication restored in bcm ebcm tbc found pcm tcm gpcm still offline traced out can lines to gpcm to tcm then to pcm found pcm was already replaced by previous shop or shop before last reinstalled original pcm communication not present but no crank ya they keep coming with this truck found crank output wire at pcm was broken in pcm connector repaired truck cranks and starts I had to relearn security of course with original pcm while running various u codes would pop up in various modules bcm tbcm ebcm found when checking can lines in the chain between modules ebcm was pulling can low circuits down replaced ebcm reprogrammed it and whollah truck is fully repaired nightmare good bye thanks all for the help
The following user(s) said Thank You: Noah, Paul P.
