Mercedes ML320 1998 with P0170 & P0173 codes
  • Bilal Ali
  • Bilal Ali's Avatar Topic Author
2 years 10 months ago #63562 by Bilal Ali
Hi dears,,,
I've Mercedes ML320 1998 with P0170 & P0173 codes with no any symptoms at any condition.
The LTFT1 & LTFT2 are about 33%, STFT1 & STFT2 are about zero.
At ideal, In live data MAF reading about 8kg/h.
When I unplug MAF its value changes to 16kg/h and STFT1 & STFT2 decrease to about -25%.
I cleaned MAF but no change.
Is this MAF issue or another issue.
Thanks in advance.
2 years 10 months ago #63565 by juergen.scholl
Replied by juergen.scholl on topic Mercedes ML320 1998 with P0170 & P0173 codes
Your MAF value is too low. Supposing you got the V6, 3.2 liter engine it should hover around12g/sec. The fact that both banks are affected in the same way may also point to a MAF issue.
Do you actually see any short term fuel trim other than 0 in any moment?
How are your fuel trims in other load and rpm ranges?
