GM HEI ignition waveforms
9 years 3 months ago #10744 by Sage
GM HEI ignition waveforms was created by Sage
I'm doing some old school work. I'm wondering where I can get a parade waveform on a GM HEI distributor. I suppose a paddle would supply waveforms but I'm not sure how good they are and I don't have a paddle. A scope on the ignition power lead I suspect would not give a proper waveform because (like a COP coil with the transistor in the coil) you are not connected to the coil. A current probe on the power lead doesn't really give you a reflected secondary waveform for the same reason with the driver being in the distributor. Finally I'm not sure what the tach output of the distributor gives. Can anyone shed some light before I start poking around. I'm looking for good secondary waveforms or reflected secondary (primary) waveforms.
Thanks
9 years 3 months ago #10745 by Ben
Replied by Ben on topic Re:GM HEI ignition waveforms
just a snapshot or a whole file ?
9 years 3 months ago #10746 by Sage
Replied by Sage on topic Re:GM HEI ignition waveforms
Not sure I understand your reply Ben. I'm asking where to hook up my scope.
9 years 3 months ago #10747 by Ben
Oh sorry I misunderstood your question I thought you just wanted to see what they looked like. Anyways to answer your question to view secondary you would need either a paddle or a secondary clamp I personally chose the paddle because you can use it on cop or ignition wires . You can view primary current with a low amp clamp on either your power or your ground of coil but you won't see the same detail as secondary ignition
9 years 3 months ago - 9 years 3 months ago #10748 by Sage
I was sort wanting to see reflected secondary waveforms or primary voltage waveforms. Not current waveforms. What does the tach output give? I presume it's conditioned somehow so it won't look right. Maybe I'll have to cobble together a paddle of some sort. I'm wanting to see the spark line and peak spark voltage (or a reflected version of it). I'm pretty sure paddle waveforms may give you the shape but all that I've seen wander all over the place in amplitude. Maybe I'm wrong.
Other suggestions welcome. Thanks
Last edit: 9 years 3 months ago by Sage.
9 years 3 months ago #10749 by Ben
You will need a low amp clamp to view primary on this coil
9 years 3 months ago #10751 by Sage
Unfortunately a primary current waveform isn't going to show me what's going on in the secondary (voltage). I have no doubt the module is working properly so the current waveforms will be ok. I'll have to play around I guess. Maybe make a simple paddle or see what the tach output delivers. Could be it will have what I want because I think it will drive old school tachs which were expecting a reflected secondary waveforms from points etc. (several hundred volts).
Thanks
9 years 3 months ago - 9 years 3 months ago #10760 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic GM HEI ignition waveforms
I discovered by accident that on some ignition systems you can capture primary waveforms by holding the scope + lead in one hand ( - to block ground) and simply holding other hand over but not actually touching a COP coil.
Edit I was using the scope this morning so I did a quick capture using above method ---
Last edit: 9 years 3 months ago by Andy.MacFadyen.
9 years 3 months ago #10761 by Ben
That's interesting Andy! this is taken with pos lead in 1 hand and other hand near a cop? What voltage setting are you on?
9 years 3 months ago #10947 by Sage
I tried the Tach output from the stock HEI distributor. It shows primary and reflected secondary waveforms fine. Just thought I'd update the thread.
9 years 3 months ago #11061 by Ben
Replied by Ben on topic Re:RE: Re:GM HEI ignition waveforms
Sage wrote: I tried the Tach output from the stock HEI distributor. It shows primary and reflected secondary waveforms fine. Just thought I'd update the thread.
Thanks for the update I'll give that a try the next time I have an hei in the shop
