2009 vw golf 2.0l drive selector lights flashing and gets stuck in second gear.
  • sebasrc_usmc
  • sebasrc_usmc's Avatar Topic Author
2 years 11 months ago #63362 by sebasrc_usmc
hey guys little back story on this vw. My friend bought a reman trans for his golf. everything works until it gets hot then she slips and get stuck in second gear. I checked for codes, i have four codes on the transmission which are: p2711 (unexpected/implausible mechanical gear disengagement intermittent), p0733 ( gear 3 incorrect ratio), p0735 ( gear 5 incorrect ratio), and p0717 ( input/turbine shaft speed sensor "A" circuit no signal).  I checked prodemand to see if there were any flow chart for these codes but no luck. I guess my question would be should I focus first on the P0717 then go after the others codes? I am assuming the two incorrect ratio are due to the speed sensor no signal, but the p2711 I have no earthly idea where to begin. Any insight on where to begin would be helpful, as I am rather new to diagnostic and learning to diagnose.
2 years 11 months ago #63394 by Noah
I would go after the speed sensor code first, see if anything makes sense.
Is it too late to contact the rebuilder of the transmission?
Time to create page: 0.247 seconds
