Diesel fuel pump regulator testing [FIXED]
9 years 3 months ago - 9 years 3 months ago #10703 by Matt
Hi
Car: 2003, Fiat ducato, 2.8l, diesel, 94kw
Problem: no power, dtc: p1671, p0191 (both: fuel pressure Regulator)
I don't have full wiring for engine, only info about pressure regulator that it is 2-terminal pwm controlled solenoid.
My scanner can activate this regulator, when i did it, no sound or klick noticeable with finger touching the solenoid. Testlight will light up normally when connected into unpluged connector and output activated (1sec on, 1 sec off). I don't have scope today but seems like it wasn't pwm test signal.
I took it off the engine and feeded 12v through testlight and then directly 12v both polarities- there was no moving of the pin or any sound. Coil resistance 2,2 ohm.
Is this test conclusive that pressure regulator is faulty?
Last edit: 9 years 3 months ago by Matt.
9 years 3 months ago #10767 by Ben
Replied by Ben on topic Re:Diesel fuel pump regulator testing
Doesn't sound good for it! I would be interested to see what amperage was but it probably doesn't matter if your pin isn't moving that's a problem!
9 years 3 months ago #10786 by Matt
Replied by Matt on topic Re:Diesel fuel pump regulator testing
Thanks for replay. Already did put in new pressure regulator solenoid... car is fixed. Tho...interestingly there was also no clicking or moving with the new solenoid. I tried to energize coil through incandescent testlight, maybe it wasnt enough voltage then.
9 years 3 months ago #10788 by Ben
I was thinking about that the light probably wouldn't let enough amperage through to activate the solenoid anyways. Glad it's fixed though!
