2004 Envoy fuel tank pressure sensor
- bruce.oliver
- Thank you received: 88
9 years 3 months ago #10688
by bruce.oliver
2004 Envoy fuel tank pressure sensor was created by bruce.oliver
Not a question, but may have a question tomorrow. Lol
Trying to help a guy at work, but didn't get to spend much time on it. 2004 Envoy fuel tank pressure sensor issue. Stuck at 1.50 volts. He put a new sensor in and it shows 2.73 volts on the scandata. I spent a few minutes trying to help him and with the old sensor plugged in and volt meter on the signal wire shows .220 volts, but scandata showed 1.51volts. New sensor volt meter shows 1.44 volts but scandata shows 2.73 volts. Sensor unplugged scandata shows 1.29 volts, but volt meter shows 5 volts on the signal wire. 1.29v + 1.44v = 2.73v. 0.22v + 1.29v = 1.51v. Weird problem, think I'll suggest a different scantool first then check wire integrity. I'll reply tomorrow to let yall know what we find.
9 years 3 months ago #10695
Replied by Tyler on topic 2004 Envoy fuel tank pressure sensor
Subscribing for later, 'cause I got nothing. :lol: Unless the scope/DMM ground is poor?
- bruce.oliver
9 years 3 months ago #10702
by bruce.oliver
Replied by bruce.oliver on topic 2004 Envoy fuel tank pressure sensor
This was a weird one. After checking, double checking and triple checking with different meters and 3 different scantools we called the pcm. Then we decided to clear the code out and everything started working right.
- Thank you received: 1138
9 years 3 months ago - 9 years 3 months ago #10713
Replied by Noah on topic 2004 Envoy fuel tank pressure sensor
Unexpected.
Glad it's back to normal though!
Do you think it could have been ignoring the signal and substituting a value because it already determined there was an issue?
Last edit: 9 years 3 months ago by Noah.
9 years 3 months ago #10724
Weird.
I like what Noah is thinking about a substituted value but... Why would it bother? :lol:
I was gonna suggest a soft reset, but I guess that would have accomplished the same thing.
