1995 Jeep 4.0 - lopes at idle - rich condition
- 04300EXC
2 years 10 months ago #63704
by 04300EXC
Replied by 04300EXC on topic 1995 Jeep 4.0 - lopes at idle - rich condition
comment about port injection makes sense.... thanks,
Anyone know whats up with my secondary ignition pattern? Its looks like waves how the parade goes up and down. and the spark lines are not consistent. Engine still struggles at idle and exhaust smells of fuel.
- 04300EXC
2 years 10 months ago #63721
by 04300EXC
OK - ran some secondary ign scopes on each of the six cylinders ( set scope to the 1ms/s, one lead on the dist coil wire, 2nd lead on each individual cylinder plug wire). Cylinder 5 has what I think are lean patterns that occur randomly but frequent (within about every 10 cycles) and have up to 3 of these patterns in a row (see pict 1)(pict 2 is the next pattern on cyl 5 right after pict 1 - looks normal?). Cylinder 5 also has what I think are low or weak spark lines? (as low as 8 KV see pict 3). There are also some patterns that have the spark line spike down below zero, not sure what that is, but that seems to happen before the lean patterns start (see pict 4). Cylinder 6 has same patterns as cylinder 5 but not as many. Cylinder 1 and 3 have same pattern, but much less frequent, Cylinders 2 and 4 do not have these patterns and look pretty good to me? (see pict 5)
what do you guys see in these patterns?
- 04300EXC
2 years 10 months ago #63722
by 04300EXC
second pict
- 04300EXC
2 years 10 months ago #63723
by 04300EXC
3rd pict - cyl 5 low spark kv
- 04300EXC
2 years 10 months ago #63724
by 04300EXC
pict 4 - cyl 5 spark line below zero
- 04300EXC
2 years 10 months ago #63725
by 04300EXC
pict 5 - cyl 2 - looks normal?
