Misfire P0300
- flame102
9 years 3 months ago #10580
by flame102
Misfire P0300 was created by flame102
2012 chevy Silverado 3500 6.0l,scanner shows 30 misfire on #4 cly. short terms readings are good..compression good .
swapped one at a time coil,wire ,plug to a good cyl. no change.check for vacuum leaks, no leaks ... Any suggestions ??
- cheryl hartkorn
- Thank you received: 130
9 years 3 months ago #10584
by cheryl hartkorn
Replied by cheryl hartkorn on topic Misfire P0300
injector flow test yet?
- cheryl hartkorn
9 years 3 months ago #10585
by cheryl hartkorn
vacuum reading nice and steady?
- Ben
- Thank you received: 215
9 years 3 months ago #10607
by Ben
Replied by Ben on topic Re:Misfire P0300
An injector flow test would be a good step, it sounds like you've covered ignition pretty well
9 years 3 months ago #10616
Replied by Tyler on topic Re:Misfire P0300
Is this a misfire you can reproduce, or are you just seeing the misfire history? Freeze frame data might be useful in this situation.
I have seen AFM lifters fail intermittently, but you have to catch it in the act to prove it.
- flame102
9 years 3 months ago #10674
by flame102
Replied by flame102 on topic Misfire P0300
Have not done a injector bal,but I have disconnected the injector and the misfires counts go up from 30 to 120 and it feels like is missing worse.
- flame102
9 years 3 months ago #10675
by flame102
vacuum is steady on the scanner ,{Have not used a manual gauge} ...
