2001 Ford Expedition 5.4 triton 2 valve with 218k on it.
I have a weird issue with my expedition, intermittently the speedometer will go flat and the transmission will jump out gear and
I coast to the emergency lane to where I wait 10 minutes or so and I can start her back up and she will go again for a little bit or
take me straight home. I changed the upstream oxygen sensors as the right one was shorting out on the exhaust manifold. then
i found that my MAF sensor was not reading right so I changed that out too. the SUV seems shaky at idle and flooring the gas
pedal it seems it wants to but is not giving it. When I move the wire bundle from the PCM I can hear the RPMS move to 1500rpm
and I see my voltmeter on the TPMS sensor 5v drop from 5 to 4.8 and sometimes just 0volts but then comes back to either 4.8 or 5v
again. all grounds to PCM are good and I measure 12 volts on the PCM for 5v reference.
Could the shorted Oxygen sensor mess up the PCM ? all the pins are clean and on the connector it all seems fine too.
Any help would be appreciated.
Last edit: 3 years 1 month ago by vanschijndelpascal@gmail.com.
Does the engine die when the speedometer goes flat?
You have 12 volts on the 5v reference?
What method are you using to check PCM grounds?
"Understanding a question is half an answer." I have learned more by being wrong, than I have by being right.
