2010 Expedition u210b Fixed
- bruce.oliver
- Thank you received: 88
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- cheryl hartkorn
- Ben
- Thank you received: 215
If you do not find voltage, then go the FPDM and recheck. If you still don't have voltage, then check pin fitment and FPDM power/ground before replacing the FPDM. If you Do find voltage, then check the ENS circuit for an open/high resistance.
Condensed the flow chart for ya. :lol:
- bruce.oliver
Yes it is the ENS circuit. I already went through the testing and we have a RCM on order.
With everything plugged in, RCM and FPDM, the ENS wire is grounded. Still grounded when I unplug the FPDM. With both unplugged the wire has nothing on it. With the FPDM plugged in and the RCM unplugged the wire has 12 volts on it.
I'll report back after the RCM is replaced and programmed
So, did you happen across anything that explains the exact purpose of this circuit? I'm guessing it has something to do with shutting fuel off in the event of a crash, but I thought that's what the inertia switch was for.
- bruce.oliver
- bruce.oliver
bruce.oliver wrote: The description on prodemand for the ENS circuit said it replaced the inertia switch. I'll go back and reread it and check to see if it has an inertia switch whenever we get it back for the RCM.
Sweet! Wouldn't be the first time a diagram was wrong, either. :lol: I'm guessing this Expedition still starts and runs, right? Wondering if this circuit can cause a no start...
- bruce.oliver
New RCM installed and programmed. KOEO and KOER the ENS circuit has a 0-12v squarewave. With the old RCM it had constant 0v
bruce.oliver wrote: It dones have an inertia switch in the left rear corner.
Interesting... Just one more thing to go wrong, I guess. :lol:
Thanks for letting us know how it turned out!
- Ryansookwah
