2005 Chrysler Hard starting and no start
- davidessiendcarguy
3 years 2 months ago #62523
by davidessiendcarguy
2005 Chrysler Hard starting and no start was created by davidessiendcarguy
I was called to another garage to fix a 2005 300c chrysler with a v6 engine and an automatic transmission. The problems they noticed with the car was Hard or no start, no throttle response,battery and ESP light remaining ON, most times immediate stalling after starting however, if it doesn't stall there's a rough idle throughout idling as a result an old PCM was replaced with a new one however problem still persisted.
I did all system scan and saw a P0340, P2167, P2166, P2115, P2116, p0603 and more module codes like C2202, U0168, U1414, B1A25, etc.
Only DTC scan I got p0403, p0403, p0340, p0052, p0058
Please, how can I fix these problems?
The major problem is that whenever the red round light probably, the security light, if it remains ON, the car won't start at all however even if it does start by chance, the car would definitely stall immediately.
On the otherhand , if the red perhaps security light blinks and battery light goes off, it will have only hard starting but would definitely start. Firstly, how can I fix the security issue? The client said: "he doesn't want anything security in the car anymore." How should I proceed to disabling that security completely? It's because of that that made the engineer encourage them to get a new ECU.
Please, help me with the repair procedure and also wiring diagram showing power distribution layout identification for the engine bay and rear fuses.
and explains more what I'm trying to explain.
- Thank you received: 1139
3 years 2 months ago #62524
Replied by Noah on topic 2005 Chrysler Hard starting and no start
Please include the descriptions for the codes you are trying to fix. That way everyone doesn't have to jump back and forth trying to Google code descriptions and such.
As far as all the wiring diagrams, repair procedures etc, Mitchel DIY is an affordable resource for access to all the same information Scanner Danner uses in his diagnosis, only for a single car. You can easily charge this fee to the customer.
As far as deleting the security system all together, you will likely not be able to do this. There are programs like HP tuners which have the capability to do this, but that is beyond the scope of diagnosis and repair. Typically this is something offered by a tuner shop, a place with a dyno and racecars. Your average repair facility or dealership will not offer this service.
3 years 2 months ago #62525
Replied by davidessiendcarguy on topic 2005 Chrysler Hard starting and no start
This link below shows further what I noticed about the car.
With testlight connected to ground without switching on the ignition, I noticed that a particular fuse actuated the relay. Hence, I pulled it out. And tested the relay circuit.
3 years 2 months ago #62526
Please, what could be responsible for that? Is it responsible for the problem?
- ferris48
- Thank you received: 47
3 years 2 months ago #62529
by ferris48
From watching that video I think the flashing light when the car stops running is most likely from the blower motor. If you have blower motor operation with vehicle running, perhaps this blower motor has bypassed that Run Relay to receive ignition run voltage from elsewhere. Pull out Fuse 42 and see if the light still flashing when the vehicle stops running. If not try the other fuses I have highlighted at the PDC.
Replied by ferris48 on topic 2005 Chrysler Hard starting and no start
Time to create page: 0.266 seconds
