09 Nissan murano
- calobeto.ibarra
3 years 2 months ago #62488
by calobeto.ibarra
09 Nissan murano was created by calobeto.ibarra
Jus a cuestion to how do I connect my leads to do a ignition coil test I have verus d10 I want to see the bad one before I put the new one in
- juergen.scholl
- Active partschanger
- Thank you received: 462
3 years 2 months ago #62492
by juergen.scholl
Replied by juergen.scholl on topic 09 Nissan murano
Supposing you're dealing with 3 wire coils....
One should have a permanent battery voltage feed with the engine cranking or running. Another wire is a permanent ground. The third wire, with a smaller diameter, carries the activation or trigger signal from the pcm to the ignition module which is integrated into the coil.
Being this type of coil you will not be able to capture primary ignition voltage. You can capture the trigger signal on that 3rd, smaller wire, typically it's around 3,5 to 4,5 volts.
If you had an amp clamp you would be able to measure primary current, hooking up to anyone of the permanent feed or ground wire at one time will allow this.
Without a dedicated probe you still can get a secondary ignition voltage capture: just place the tip of your test lead around or on top of the coil. Then move it a little bit to figure out where the signal is strongest. Laying a penny/coin on top of the coil and holding the probe to it will enhance the signal further.
Obviously this secondary capture would not be voltage scaled properly.
- juergen.scholl
3 years 2 months ago #62493
by juergen.scholl
You also can look up procedures within in the components test menu of your Verus'. You'll find car specific informations on components, wires, how to connect and so much more. A really helpful option to get you going with scoping.
- calobeto.ibarra
3 years 2 months ago #62495
by calobeto.ibarra
Replied by calobeto.ibarra on topic 09 Nissan murano
Thank you so much, yes I was looking at my verus and my only concern is that do I need an attenuator so it doesn't smoke my scanner? Or not need it
So I can backprobre any coil? Cause the misfire is on the cilynder #2 witch is very convenient right off front of me and I do have a low amp probe
Thanks again
Thanks again
- calobeto.ibarra
3 years 2 months ago #62496
by calobeto.ibarra
Low amp clamp not probe sorry
- juergen.scholl
3 years 2 months ago #62498
by juergen.scholl
The Verus is safe up to 400 volts. This enough for ignition primary. You don't need an attenuator with your Verus.
- calobeto.ibarra
3 years 2 months ago #62499
by calobeto.ibarra
Last one, so I can test any coil 1 or23456
Thanks man sorry for bothering you I really appreciate you taking the time to help me
I'm learning still
I'm learning still
- juergen.scholl
3 years 2 months ago #62500
by juergen.scholl
Yes. You can test any of the 6 coils.
