abs light
  • sleepless
  • sleepless's Avatar Topic Author
3 years 2 months ago #62419 by sleepless
abs light was created by sleepless
I have a 2002 ford E150 ford van and when I went out to start it this morning, it wouldn't start, and was showing an abs light, should not the van still start? even with the abs light on, or could I have some other problem, the battery, the alternator, fuse, relay. Are there any tricks to test which wheel has the problem? I have no scan tools and can't seam to scrape up the money for your book, any help would be appreciated. Thank you. Daniel Kinney
3 years 2 months ago #62420 by Noah
Replied by Noah on topic abs light
The abs light most likely has nothing to do with why it won't start.
Does the starter turn the engine?
  • sleepless
3 years 2 months ago #62425 by sleepless
Replied by sleepless on topic abs light
Yes sir, the van does absolutely nothing in the key run position. Today I plan on jump starting the van see if it starts, if it does, I'll try some fuse checks, and if there's a relay, I'll try to find it as well, will let you know what I find when I get that far. Maby I'll try some of the things Mr. Danner has shown me in the past, tapping the starter, and checking the battery, the basics, I guess. If I get the van started and it moves, is there any way of telling which censor on what corner it may be? The only tool I have is a small obd reader, it will at least give me a code number.Thank you very much for your help and concern, This fourm is the best. Sleeples.
Time to create page: 0.241 seconds
