2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
  • jaivs26
  • jaivs26's Avatar Topic Author
9 years 4 months ago #10424 by jaivs26
HI everyone!
I'm working on a '01 Tahoe with the 5.3 The computer is not sending the signal to the coils #5, 7 and 8. I'm not familiar with this 24X crankshaft 1X camshaft relationship.. i'm looking for some information and maybe a known good CRANK/CAM sync waveform..
I have to crank the engine for 10 seconds to make it run but it only runs at 380/500 RPM sometimes i get P0336 CKP "A" (18/24X) OUT OF RANGE. But i think i'm getting this code because i'm cranking the engine to much to get it running!
The following user(s) said Thank You: Al4171990
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 4 months ago #10435 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
do you have power and a ground to these coils? or just no control?
  • jaivs26
9 years 4 months ago #10439 by jaivs26
Replied by jaivs26 on topic 2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
I just don't have the control signal from the computer
  • cheryl hartkorn
9 years 4 months ago #10441 by cheryl hartkorn
id check it at the engine control module next. to eliminate broken control wires
  • jaivs26
9 years 4 months ago #10443 by jaivs26
Replied by jaivs26 on topic Re:2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
I did check the control wires for all the coils they are OK.. I just received a ecu that i ordered and still the same. I'm researching right now how the computer receive the signal to fire the coils.. But no luck so far
Sent from my A0001 using Tapatalk
9 years 4 months ago #10444 by Tyler
Replied by Tyler on topic 2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
I'd absolutely follow the P0336. The 24X signal on this engine is kinda bananas, as it's actually two separate reluctors sandwiched together on the crankshaft. The CMP is just a high/low transition every crank revolution.
It's kinda tough to tell in that capture, but there's intermixed short and long pulses at work. If you can capture the CKP while the engine is idling, then I'd suggest making sure that there are indeed 24 pulses in one CMP pulse. Anything less will confuse the PCM.
The following user(s) said Thank You: jaivs26
  • jaivs26
9 years 4 months ago #10446 by jaivs26
I will try to capture CKP and CMP tomorrow! And post screenshot of the waveform
9 years 4 months ago #10454 by Tyler
Replied by Tyler on topic Re:2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
Sweet, thanks sir! This is an interesting symptom, so I'm very curious to see what you find.
  • jaivs26
9 years 3 months ago #10473 by jaivs26
Here is the waveform!
9 years 3 months ago #10476 by Tyler
Thanks, sir! Could you email me that VSM file? wrenchturnsyou@gmail.com
I'm interested to take a closer look, as it appears that the last pulse of the CKP gets cut off by the end of the CMP pulse. Might just be the way the image came out?
9 years 3 months ago #10494 by Tyler
Thanks for the waveform! Had a look, counted the CKP pulses. Definitely had all 24 pulses within the CMP window. I got a little concerned at how close the last pulse is to the end of the CMP, but I'm not convinced this is the issue:
This was during cranking, correct? Do the same three coil not have spark during cranking, as well as idling?
  • jaivs26
9 years 3 months ago #10497 by jaivs26
Tyler wrote: Thanks for the waveform! Had a look, counted the CKP pulses. Definitely had all 24 pulses within the CMP window. I got a little concerned at how close the last pulse is to the end of the CMP, but I'm not convinced this is the issue:
That was at cranking!
One thing i noticed when i was triple checking the inputs at the coils is that in the first cranking i get one and sometimes 2 spark at the coil # 5..
Im going to check it again and i post any update
  • jaivs26
9 years 3 months ago - 9 years 3 months ago #10504 by jaivs26
Here is a screenshot of the CKP,CMP and coil #5 on initial cranking .. it's getting just one or some times 2 signals every time i first crank the engine.
i checked the other "2 faulty" (coils 7 and 8 ) coils and i'm not getting any signal at all on initial cranking.
Last edit: 9 years 3 months ago by jaivs26.
9 years 3 months ago #10511 by Noah
Replied by Noah on topic 2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
It probably doesn't indicate anything, but I'm noticing that a lot of the noise on the turn on pattern just kind of goes away after that initial turn on.
Did you happen to capture a known good from a working coil?
  • jaivs26
9 years 3 months ago #10536 by jaivs26
HI NOAH!
Here is a capture of a CKP( BLUE) COIL#1 (YEL) COIL #2 (GREEN). I connected the ground at the battery. And to be honest i can't remember where i connected the ground when i test the COIL#5..
i think the noise it's because the starter is cranking the engine! don't you think ? i did notice the noise but i just tired of this truck that i didn't care much.. but tomorrow i will check it again to make sure where i connect the ground..
9 years 3 months ago #10564 by bruce.oliver
Replied by bruce.oliver on topic 2001 Chevy Tahoe 5.3 No Spark In 3 Cyl.
Are you checking the signal wires with the coils unplugged? or have you swapped or replaced any of the coils?
Maybe something weird on those coils shutting down the drivers
9 years 3 months ago - 9 years 3 months ago #10566 by Tyler
So I've been beating my head against the wall on this one. :lol: To be completely honest, I probably would have broken down and tried a crank sensor already.
Started thinking about the cylinders that are missing spark. The firing order is 1-8-7-2-6-5-4-3 on this engine, which slices up like this:
1-8-7-2
6-5-4-3
So #8 and #5 are companions, two of the cylinders we're missing spark on! #7 is just after #8, so maybe there's something to that? Anyway, I started wondering if there's something wrong with the crankshaft reluctor, as #5 and #8 are 360 crankshaft degrees away from each other.
Threw the overlay program up over the coil trigger waveform jaivs26 posted, hoping to associate crank pulse groups with specific cylinders.
If I did it right, then it's the second group that's associated with #5 and #8. The short-long-long-long group, right after the initial short-long-long-long-long-long. But, I can't find anything wrong with it! :lol: :silly:
Last edit: 9 years 3 months ago by Tyler.
  • jaivs26
9 years 3 months ago - 9 years 3 months ago #10573 by jaivs26
I want to thank everyone for helping me with this problem. All have been very helpful!!
today i was checking it again a notice that the alternator was getting hot just a few minutes when the engine was running.
and something weird to me happened the engine start to get more speed. Unfortunately it didn't fix anything.
I tested the alternator with the KOEO and heres the capture
I also recored a small clip when i found this
  • jaivs26
9 years 3 months ago #10574 by jaivs26
i did swapped the coils and i'm checking the signal with the connectors plugged in!
9 years 3 months ago #10578 by Tyler
I can't watch that video right now. :-( But it seems like unplugging the alternator improves the symptoms? I'd be interested to know how much AC ripple is present at the battery.
Thinking back now, that'd probably explain all the noise in the CKP signal peaks...
Time to create page: 0.395 seconds
