[FIXED] 1994 Chevy Suburban C1500 - cranking, no start
- popoften
- Thank you received: 22
My son was driving the truck and it was running fine. After about 30 miles of highway driving, the truck completely stalled out while stopped at a traffic light and would not restart. The engine would crank fine but it would not fire at all. He attempted restart numerous times with no success.
We had the truck towed back home so I could have a look at it. At my garage I also attempted to restart it. It would crank fine but did not fire at all. I could hear the fuel pump prime when I would turn the key to the On position. I also opened up the throttle body and attempted to start while spraying starter spray into the throat of the throttle body. Again, it cranked fine but it did not fire at all. So then I thought I would check for spark. I hooked a spark checker to cylinder #1 and it indicated that I was getting good spark. After the initial test of the spark I thought I would repeat the test. When I cranked the engine that time there was a slight indication that it wanted to catch and fire. But it did not start. When I repeated the spark test a third time the engine cranked but did not start and did not fire at all but again the spark checker did show I was getting spark. By then it was late and I decided to to come back two days later on Saturday morning to continue my tests.
On Saturday morning I thought I'd do a quick compression test. So I pulled the spark plug from cylinder #1. The plug itself looked okay and the gap was fine. I installed a compression gauge and lo! and behold! the engine started right up. The compression reading was 132psi which is a little below spec but the engine has almost 200,000 miles on it so that did not concern me. I was a bit baffled as to why the engine is now suddenly starting. I reinstalled the spark plug and connected the wiring and started the engine again and it ran fine. So it seemed to me at that point we have some kind of intermittent problem (I know, call me Captain Obvious!). I did a little poking around. I noticed that the distributor cap was a little bit loose so I tightened down the screws about 3 turns each. The distributor cap is now tight and secure. I doubt that the distributor cap was the problem. But at the same time, the truck is running now. I've driven it 30 miles with no problems. The only other thing I can think of that it might be is maybe the computer is getting a little schitzy.
What I am minded to do right now is just drive the truck around town as usual and see if it acts up again. If it does, I'll probably have a look at the computer and its connections. Any ideas or suggestions that you guys might have would be appreciated.
Another thing to look for would be the injectors spraying during the crank no start. I dunno that lack of fuel is your problem (since adding alternate fuel didn't help), but it would tell you something about the state of the PCM. If it's pulsing both injectors, and fuel is spraying out, then you can probably eliminate fuel and the PCM as potentials.
- popoften
Thanks again!
Pop
- popoften
- popoften
- Ben
- Thank you received: 215
- toadyboy1957
- popoften
- sbirchmeier
- Ben
- csipes1983..
- Thank you received: 6
- popoften
- Rockyroad
- Thank you received: 7
P.s. keep the old one in the glove box. If it ever happens again,you know it's good for about 30mi.
Someday I'll figure this out
- popoften
So, it would seem, the problem is the injectors. Can I repair the injectors, or do they need to just be replaced?
popoften wrote: So, it would seem, the problem is the injectors. Can I repair the injectors, or do they need to just be replaced?
I was actually wondering about low fuel pressure, and how that might produce the injector spray (or lack thereof) that you noted. Without enough pressure behind them, the injectors can't produce the normal spray pattern they should.
The trouble is measuring fuel pressure... I don't think these TBI systems have Schrader valves, so you may have to get a gauge in-line with the pressure side. 9-13 PSI with the engine running is what you're looking for. A deadhead test might be a good idea, too. I would expect to see at least 25 PSI, preferably closer to 40 or 50 PSI.
- Rockyroad
- popoften
I replaced, and drove the truck almost 200 miles today and it is running fine.
Thank you for all your insights, guys!
- popoften
- popoften
