map sensor
- jundudz
3 years 2 months ago #62386
by jundudz
map sensor was created by jundudz
I got a problem with my map sensor in a chevrolet optra, it has a reference volts reading 5.3 but the problem is i cant get a ground reading. Whats probably the cause?
- juergen.scholl
- Active partschanger
- Thank you received: 462
3 years 2 months ago #62387
by juergen.scholl
Replied by juergen.scholl on topic map sensor
What exactly does it mean "can't get a ground reading"?
If you're measuring reference voltage - around 5 volts - on the ground wire of the sensor then you got an open ground. If you measure anything higher than 0.1 volt but less than 5 volt reference voltage then you're dealing with unwanted high resistance on that very ground connection
- jundudz
3 years 2 months ago #62388
by jundudz
Replied by jundudz on topic map sensor
I was testing the ground wires continuity and i cant get any signal. There is no cuts in the wire though
- juergen.scholl
3 years 2 months ago #62396
by juergen.scholl
How exactly did you check for continuity?
If indeed there is no continuity from one end of the wire to the other end then there MUST be an open! It may be hidden under the insulation/lagging.
- jundudz
3 years 2 months ago #62403
by jundudz
Hi sir, i switched on the car then testing the three wires of the map sensor, one wire has a 5.03 volts so im sure its the reference voltage, ive come up to find the ground wire by testing it with a multimeter (continuity test) the remaining two wires are both not responding or no continuity.
- jundudz
3 years 2 months ago #62404
by jundudz
I tested it from the negative terminal of the battery to the sensor and like i stated there is no continuity.
- jundudz
3 years 2 months ago #62405
by jundudz
Actually the main problem of this car sir is that it has a dtc P0107 (map sensor low voltage) im just checking the wirings if the problem lies there for i dont want to waste money for a new map which is a little bit costly
