ECM power
  • Sleepers
  • Sleepers's Avatar Topic Author
3 years 3 months ago #62225 by Sleepers
ECM power was created by Sleepers
Hello, I have a 1999 jeep Cherokee sport that has suddenly developed a crank no start. Upon testing the fuses. Fuses 23 and 21 in the engine bay fuse panel have no power, no blown fuse. No power with or without ignition power. All other fuses have power. Diagram says this is the Ecm, injectors, coil ect. My question is how do I diagnose/fix the no power to these two fuses?
TIA
3 years 3 months ago #62237 by JoshuaK
Replied by JoshuaK on topic ECM power
You need a wiring diagram, and then you'll have to trace it back. Do you have access to those? One possible scenario is that a relay feeds those fuses, and the relay is bad or is missing control.
  • Sleepers
3 years 3 months ago #62242 by Sleepers
Replied by Sleepers on topic ECM power
Does the ECM power up the ASD relay? If so, where does the ECM get its power from? What electric path leads to the ecm.
3 years 3 months ago #62246 by JoshuaK
A wiring diagram would answer that. The ECM probably has several powers and grounds.
  • Sleepers
3 years 3 months ago #62303 by Sleepers
Got the wiring diagram. Those fuses are powered by relay from the Ecm to the asd relay. Going to probe the Ecm powers today but I am almost full convinced the problem is the Ecm. Ref voltages are all 3 volts with sensors unplugged and the Ecm is not energizing the asd when keyed to run/start.
Time to create page: 0.260 seconds
