2010 Scion XB P0171
- Stryper
I am using a Topdon Artidiag Pro scanner and ordered SD's book. I am no longer in car biz, and no wish to return, its just my hoopties. And I live across from a Toyota Service director so i have little faith in dealer diagnosing
LT trim is 22+ to almost 40 at snap throttle
ST trim goes from -18 to +7 " " " " "
MAF goes from about 4gms to over 45 on snap throttle
AFS is going from -1.6 to +1.6
I'm kind of leaning to AFS being wonky as it should be 3-4 area correct? Cause it still acts like a battery right?
I would add the truck has 250K + and I have gotten my monies worth
- pinstryper
- Cheryl
- Thank you received: 215
- pinstryper
Still unable to combine graphs on my scanner.
- pinstryper
- Stryper
TIA,
Michael
- Tutti57
- Thank you received: 254
What is the vehicle you are working on, and if you want to share some of what you are dealing with, you may get some more help here?
- Stryper
Vehicle runs too good to have a fuel delivery issue, but he might as well check pressure anyway.
And injector ms and FT limits are shots in the dark at this time. ANY info just might be handy at this point
will add pics from phone below
- pinstryper
- juergen.scholl
- Active partschanger
- Thank you received: 462
In general I have seen a good number of Toyota engines with dirty injectors exhibiting similar symptoms: lean code(s) without driveability issues.
With no unmetered air and fuel pressure in spec you want to look close at the injectors.
- Thank you received: 1138
Please try to keep questions about the same car within the original thread. It makes it MUCH easier for anyone trying to help you, and for people who may have a similar issue in the future.
No harm done
- pinstryper
thats the only issue i have not tested, just because it does not exhibit usual low pressure drivability issues.
Whats that 'when all other avenues ' quote?
- Monde
- Thank you received: 43
- STIMECE
- pinstryper
And being fixing drivability issues has not been my day job for 40 yrs. I actually replaced. MAF and AFS with new Densos and saw same readings.
Its an injector issue i am 90% sure, cause it runs to good at 60-70 mph but still reads over 35 % LTFT.
If he does not find time to run fuel pressure test and install the rebuilt Denso injectors by end of today, i will have it towed back and do them myself.
And now my junk Topdon ArtidiagPro will only charge thru vehicle on top of being unable to graph 4 items at once!
I spent day yesterday calling in favors from dealers i work for and the Toyota tech looked at my screenshots and and actually was impressed i kind of knew what i was talking about, but he was also in his 60's.
- STIMECE
Going 60 to 70mph is not really constructive, load is more pertinent in this case and the associated LTFT, STFT Upstream and downstream %'s and V's
So under full load you have a max LTFT value....plus 40%LTFT's and a STFT around 0% and a low downstream V you have having a fueling problem.
Although I wonder what the case would be if the voltage was high on the down stream
- Stryper
Thanks Ya'll
Michael
- juergen.scholl
finally ! Just wanted to Shout out to Ben and Juergen ! 717 and 117 issues are fixed ! Turns out Fuel Pump and the Input sensor. And finding wire colors sure helps. The only toyota input sensor video is NOT input but output
guess I need to comment on that guys post, but who would think the input is farthest from engine ?
Thanks Ya'll
Michael
Thank you for the update! Good to know you fixed it.
