1997 Mitsubishi Montero Sport Rough Idle, Lack of Power, P0300
  • shepherdguy
  • shepherdguy's Avatar Topic Author
9 years 4 months ago #10298 by shepherdguy
I have hit a dead end trying to troubleshoot an issue with my Montero Sport. I am getting a P0300 DTC with a lack of power and rough idle. I have determined that I am not getting spark at one of the coils. Backprobing the primary feed to the coil shows no pulse coming from the Ignition Power Transistor using a test light. Before I continue, I should note that I do not have a labscope or access to one, so all my testing is being done with a test light and multimeter. My skill level from a mechanical standpoint is pretty decent but from electrical, I'm pretty much novice level - or slightly above novice.
To continue, I backprobed at the power transistor and have no test light pulse on the bad feed. And in case it makes any difference, I did swap the coils and the problem did not follow the coil (coils were returned back to their original location). I followed a mfg. procedure from AllData for testing continuity on the Ignition Power Transistor using a 1.5v power supply and all three drivers pass continuity. Using the test light I checked for voltage between the PCM and Power Transistor and get a good strong light from the two good feeds but a weak light from the bad feed at both the PCM and Power Transistor ends of the wire. Everything, to me, seemed to point to a driver in the PCM. I tried to get feedback from a couple of Mitsubishi-experienced mechanics on JustAnswer.com and both seemed to agree that the problem was the PCM. So I went ahead and replaced the PCM but I still have the same issue.
I just don't know if there is something on the other side of the PCM I am over looking or if I potentially popped the driver in the new PCM? Resistance on all three wires between the PCM and Power Transistor are all the same (0.4 ohms) I even tried to temporarily replace the wire between the PCM and Power Transistor and it made no change.
If I did pop the driver in the new PCM, then I need help in troubleshooting the cause. I did review a video Paul Danner posted about a vehicle that had a coil with high amps that may have fried the PCM. I'm thinking I may possibly have the same or similar issue. But again, I do not have a scope w/ amp probe and attenuator to check waveforms. Can someone please help? I cannot replace the PCM again without determining root cause or even determining for sure if it is the PCM. I know Paul is the master with this but I also know he is very busy and cannot possibly answer each person needing help. I am praying someone out there can lead me in the right direction.
By the way, I did check the resistance on both the primary and secondary sides of all three coils and all three are within mfg. specifications but I know that Paul doesn't put a lot of stock in coil resistance readings. Any thoughts or advice???
9 years 4 months ago - 9 years 4 months ago #10311 by Tyler
Hey shepherd guy, welcome to the forums!
For my reference (and others following), this is the ignition system wiring diagram:
I'm a bit confused about your testing, since you mention testing battery feeds at the PCM and power transistor, but neither one provides battery power on this circuit. The ignition coil primary control wires at pins 11, 12 and 13 can and should pulse a test light connected to B+, but none of the PCM control wires at pins 1, 2 and 3 will. Those are low current 0-4V square waves produced by the PCM. I'm really not trying to lecture! Just want to make sure I understand the testing you've done.
I think you hit the nail on the head with this test, but I just want to clarify. When you got a weak light, which pin were you touching, and what polarity was your test light connected to?
FYI, I've personally seen two different Montero's with the 3.0L have this exact same symptom, and in both cases it was due to a jumped timing belt. ;-) With the timing out, the cam/crank signals get out of sync, and the PCM stops sending a trigger signal for one of the coils, and you wind up with a two cylinder misfire.
Why doesn't it set cam/crank codes? Good question. :lol: Anyway, before you go much further, I'd suggest pulling the two upper timing belt covers and see if you can line up the timing marks. The other common issue is the crankshaft sensor reluctor slipping off the crank sprocket. The reluctor is roll pinned to the sprocket, and have a tendency to shear off. If this happens, you end up with correct timing belt marks, but an incorrect cam/crank relationship.
Last edit: 9 years 4 months ago by Tyler.
  • shepherdguy
9 years 4 months ago #10315 by shepherdguy
Thank you for the reply and sorry for the confusion. I got pulse on the test light (Bat+) on the wires between the coils and Ignition Power Transistor for 12 & 13, but not 11. On the other side of the Power Transistor, and with Test Light still on Bat+, I get the test light to illuminate on 2 & 3, but not 1. Same results when back-probing at the PCM - test light illuminates on 10 & 23, but not 11 (these are ground-side triggered it would appear?). Prior to posting the initial post, I had checked the timing. With the crank timing mark lined up and cyl. 1 at TDC, the timing mark on the right head was right on. On the left head (the one with the CMP, the timing mark is off by less than 1/2 tooth, but if I were to move it one tooth either direction, it would be further off than it is now. Both reluctor wheels appear to be tight and in time. The crank reluctor wheel has the notch in the wheel lined exactly with the mark next to the CKP. I suppose the 1/2 tooth could potentially be hitting the vanes for two signals but just barely missing the 3rd. would half a tooth be enough to cause that? This is where a multi-channel scope would be handy because I could see the alignment of the waveforms for both crank and cam.
Another thing I had done is check powers and ground for both CKP and CMP. I then hooked a voltmeter up to the reference wire (one at a time) and with the coils all unplugged, I manually turned the crank shaft by hand bit by bit until 5V read on the meter. I used chalk to mark on the crank pulley where the 5v picked up and where it dropped. I ended with three equally sized and equally spaced chalk marks, which theoretically indicate the CKP sensor is working the way it should. I did the same with the CMP sensor but the marks don't raise or drop with one crank revolution, it would take two revolutions so I got confused with the chalk marks but it did appear to be turning voltage on and off correctly so I think the sensors are both good - it's just the timing of the two that's in question.
  • shepherdguy
9 years 4 months ago #10349 by shepherdguy
Okay, I thought I would double check my timing and I noticed something the second time around. The first time I lined up the notch on the crank reluctor wheel with the mark on the block and the timing marks on the cams looked like they were on or very close. The second time, I noticed the timing mark on the crank pulley was not exact to the TDC mark on the pulley assembly. So I lined these up exact (photo 1). Then I pulled the pulley assembly off along with the timing covers and the two cam marks were still lined up very close. But the notch on crank reluctor wheel was off slightly. I took a picture of it to get a better look and I noticed dark markings where the crankshaft gear used to be lined up in relation to the reluctor, indicating the plate has slipped from position. I have to work tonight so I will pull this off on my next day off and replace the roll pins (and reluctor if necessary). This just might me what's causing my missing signal to one of the coils.
9 years 4 months ago #10360 by Tyler
shepherdguy wrote: Thank you for the reply and sorry for the confusion. I got pulse on the test light (Bat+) on the wires between the coils and Ignition Power Transistor for 12 & 13, but not 11. On the other side of the Power Transistor, and with Test Light still on Bat+, I get the test light to illuminate on 2 & 3, but not 1. Same results when back-probing at the PCM - test light illuminates on 10 & 23, but not 11 (these are ground-side triggered it would appear?).
Wow. :blink: :lol: Thanks for the clarification! 'Cause I'm very surprised to hear that the PCM control circuits pulsed a test light connected to B+. Every Montero I've tested used positive voltage pulses to signal the Power Transistor to fire, so I'm wondering how the test light is finding a ground... Perhaps the circuit design is different on this one? :huh:
Also, my apologies, sir. I didn't know you'd been into the timing already. :blush:
Good eye. B) Let us know what you find! If possible, you can also try using a screwdriver to turn the reluctor independent of the crank sprocket? Obviously, if you can spin it, then there's a problem.
9 years 4 months ago #10466 by matt.white
I too have seen that crank sensor plate come off the pins it sits on during assembly and cause issues. Hope it's sorted.
The following user(s) said Thank You: shepherdguy
  • shepherdguy
9 years 3 months ago - 9 years 3 months ago #10472 by shepherdguy
Just an update:
I removed the crankshaft gear and reluctor plate. At first, I was concerned it might not have been the issue after all because when I flipped it over both pins were protruding through the collar. but when I tried to wiggle it back-and-forth, I noticed that one of the pins was sheared allowing the collar and reluctor plate to shift back and forth. I was unable to remove the pin half inside the gear and even broke off a small drill bit trying to drill it out. I am ordering a new gear set with new reluctor plate, pins, and collar.
Last edit: 9 years 3 months ago by shepherdguy.
9 years 3 months ago #10475 by Tyler
shepherdguy wrote: Just an update:
Thanks for the update! Well done catching the sheared pin. Brilliant design, eh? :lol: I've tried repinning these, and never had much luck. Please let us know how this ends up once you've got the timing put back together?
I know this isn't the point, but I'm still interested in why the test light pulsed when connected to B+ and touching the Power Transistor PCM wires. :blink: :lol: Do you have a scope, or DMM? I'd love to know what the voltage level is on one of those wires with the engine running. Also, if you apply the test light to one of those wires with the engine running, does that coil stop firing? Or does it continue to fire?
  • shepherdguy
9 years 3 months ago #10480 by shepherdguy
It might be a couple of weeks before I get to put back together depending on when the parts arrive. When I work, it's 12 hour shifts and will likely need to wait until my next set of days off.
As far as the PCM wires, it wasn't a pulse on that side but a steady light (or rapid pulse too quick to tell). The pulsing occurred between power transistor and coils. I wrote down in my notes afterward that the test light was hooked up Bat+ but all my notes were based on memory after all the testing was done. I'm pretty sure the wires going to the coils were tested Bat+ on memory told me I had it set up that way on the PCM side as well. But now I can't say for sure. it's highly possible I remembered incorrectly. :unsure:
9 years 3 months ago #10492 by Tyler
shepherdguy wrote: It might be a couple of weeks before I get to put back together depending on when the parts arrive. When I work, it's 12 hour shifts and will likely need to wait until my next set of days off.
No problem. :cheer: Thanks for keeping us updated.
OK I gotcha, this makes sense. I *think* you were seeing a steady light because the test light was finding a ground through the Power Transistor. Thanks for the clarification!
  • shepherdguy
9 years 3 months ago #10734 by shepherdguy
I got the new crank timing gear with reluctor wheel and collar (OEM) and installed today. Double checked all timing and everything looks perfect. Put everything back together and felt confident it was going to solve the problem, but it didn't. Still not getting spark to one of the coils. Maybe I'm doing something wrong with my testing. Can someone provide feedback on what I should be seeing from the PCM to the ignitor, and ignitor to coil? I would like to know what voltage I should be seeing, pulsing or not, and what areas should be checked battery neg vs battery positive. Thanks for any advice. This problem is really kicking my butt!
9 years 3 months ago - 9 years 3 months ago #10757 by Tyler
Man, I thought we'd nailed it with the crank reluctor. :angry:
Reposting the ignition system diagram for easy reference:
All three black/white wires at each coil should shine bright with the test light connected to B-. The control wires at each coil (brown, brown/white, brown/red) should pulse with the test light connected to B+. Do both with the engine running.
At the power transistor, pin 6 black/white should be steady power, and pin 4 black should be steady ground. You said pins 11, 12, and 13 pulsed the test light connected to B+ earlier, but maybe check again?
Pins 1, 2 and 3 will have 0-4V 'ramps' when the PCM wants to command ignition dwell and spark. Checking for control is gonna be tough with a test light or DMM, as neither is gonna be able to detect the ramps. If you really want to 'see' the control, it'll have to be a scope. :unsure:
But! You can try a 'scratch test' on the wires between the PCM and power transistor. Check out this video for the general idea:
Your Mitsu doesn't use three-wire COP's, I know, but the control system really is the same. ;-) The power transistor charges the ignition coils based on the ramps sent from the PCM. You'll just be simulating those ramps with the test light.
Basically, if you can backprobe the PCM wire at the power transistor that correlates to the coil that isn't firing, and use the test light to make the coil fire, then you know the power transistor is working. Repeat the same test at the PCM connector. If you can make the coil fire at the power transistor, but not at the PCM, then there's a wiring problem.
That test won't tell you if there's control or not, but it WILL tell you wiring integrity and the health of the power transistor. Making sense? Ask questions as needed!
Last edit: 9 years 3 months ago by Tyler.
  • shepherdguy
9 years 3 months ago #11037 by shepherdguy
Tyler, thank you for the information. I have been busy with Confined Space Rescue Training and drills but now have a chance to look at the car again. I'm not positive if I understand completely about the scratch test. Would I, for example, backprobe a T-pin at pin 1 where the wire from the PCM enters into the power transistor and use a test light to power it? Would the test light then be connected to B+? In the video, the power transistor in in the coil so I just need guidance to ensure I am making the proper connections.
Thanks for your help!
9 years 3 months ago #11054 by Tyler
[quote="shepherdguy" post=11037Would I, for example, backprobe a T-pin at pin 1 where the wire from the PCM enters into the power transistor and use a test light to power it? Would the test light then be connected to B+? In the video, the power transistor in in the coil so I just need guidance to ensure I am making the proper connections.[/quote]
Exactly. :cheer: As long as it's the 3/6 ignition coil that isn't firing, as that's the coil associated with pin 1 at the Power Transistor.
Don't touch the test light on it for terribly long, just quick taps. And have some kind of air gap set up at the coil so you can know if it's working or not.
No problem! That sounds... fun? :silly: Don't be training too hard. B)
  • shepherdguy
9 years 3 months ago #11085 by shepherdguy
Sorry Tyler, this is going to sound like a foolish question: Do I need to have the engine running to perform the scratch test? Or should it still work with KOEO? The ScannerDanner video gives me the impression he does not have the engine running while performing the scratch bypass test. I tried to perform the test with needlenose visegrip pliers clamped to ground and positioned just outside the secondary end of the 3/6 coil with the spark plug wire removed and I get no spark (test light tapping back-probed T-pin on Pin 1 "blue wire"). I tried it on one of the good coils (1/4) doing the same thing with the T-pin back-probed on Pin 2 "bk/y wire" and do not get spark on that one either, so I don't think I am doing the test right.
