2009 GMC Acadia 3.6; Engine stall
- RCPro
Reaching out for some help on a problem with a car that has haunted me 3 other tech's.
This car has a spontaneous stall. It will start fine, and idle fine, and intermediately (no correlation between occurrence and time) stall. Sometimes it will be a short time after its started, sometimes it will take 1 min, 2 min, 3 min completely (seemingly) randomly.
If you start the car and hold the RPM around 2000 it will also 'stall'. To clarify it will almost appear as if you switch the key off, and then back on very quickly, except no dash lights go off and from my diagnosing no issue with ignition signal.
There are no DTC's stored an any of the control modules at all.
We have done the following shotty, shotgun/guesswork
Replaced the high pressure fuel pump
Replaced the throttle body
Replaced the crankshaft sensor
Replaced the engine wiring harness
Replaced the ECM
Reprogrammed w/ latest update all modules equipped
Tested fuel injectors with DMM
Replaced O2 sensor
I have spent hours looking at PID's and still have no clue where to go next. The only thing I have noticed to what I can not figure out is when the concern happens the ENGINE SPEED SENSOR will read 0. So it will go from 2000+ RPM to 0 and then in the next frame jump back to 1000+ rpm. The crankshaft position sensor does not drop out nor do any of the camshaft position sensors.
The engine does smell as though it is running rich, although the fuel is not commanding any rich or lean trims.
Well that's my story, hope someone can help; this car has driven me and 3 other guys near insanity. :huh:
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- RCPro
If it does stall completely dead from say a sitting idle in park, it will start back up right away in a ordinary operation, aside from a very rich exhaust smell.
FYI, the whole TSB is seven pages long. I had to shorten it to three so I could post it here.
Would it be possible to watch the ignition coil current ramps, along with a coil trigger sync signal? The idea here would be to watch to see which coil fires right before the stutter/stall. If you can reproduce the symptom multiple times, and observe the same coil firing right before the problem, then I'd zero in on that coil.
- RCPro
I also tried unplugging the crank sensor and running it off of just the cam sensor. The same symptoms persisted. I checked the ignition switch for voltage drops or abnormality and nothing as well.
This car continues to perplex me. My gut instinct makes me think that for some reason the entire system is restarting for no known reason. As if you were very quickly turning the key of and back on while its running.
I have also replaced the engine fuse box. Usually I am very anti-parts-changer on things, but this specific diagnosis has the entire shop swarming. Any further direction is appreciated!
I know you said the module voltage data PID doesn't change, but a voltage measurement to back that up wouldn't hurt in my opinion.
- matt.white
- Thank you received: 29
- RCPro
Pins: 76, 77 on connector X1
Pins: 1,2,3,4,5,6,54 on connector X2
When engine is revving 2000 rpm and motor attempts to stall there is little to no voltage drop.
When engine is at idle and stalls it goes from charging voltage (14.5v~) to battery voltage (12v~)
I may have found something to point us in a direction. The following pictures (sorry my modis didnt wanna upload..) are graphs of the injectors. When the symptom occurs I have noticed that injector 1 seems to be missing.
The picture with the note HV,
Green is circuit 4904 Direct Fuel Injector High Voltage Cylinder 4
Yellow is circuit 4901 Direct Fuel Injector High Voltage Cylinder 1
Note labeled HV Control is backprobed at the same connector
Green is circuit 4804 Direct Fuel Injector Control Cylinder 4
Yellow is circuit 4801 Direct Fuel Injector Control Cylinder 1
- RCPro
Green is circuit 2124 IC Control Cylinder 4
Yellow is circuit 2121 IC Control Cylinder 1
Does the vehicle have to be moving to get the stall? Wondering if there's some kind of torque limiting strategy at work.
- RCPro
Maybe I should boot into the transmission side of the parameters and poke around in the speed sensors or limiting feature PID?
But on the plus side it's easily repeatable!
Is it stalling after the transition from open loop to closed loop?
The other thing I was thinking that's kind of a shot in the dark is to monitor the 5v ref circuit during the stall at the PCM. I imagine that a ref circuit problem would
a) set a code, and
b) cause at least a momentary no comm.
Not sure why this isn't setting any codes in any modules either. No pending codes either?
Checking Global OBD and Manufacturer specific? Not nit picking here, just trying to cover the bases.
- RCPro
I did all the guided test on my Modis with all four cam position sensors and cam actuators just for something to do I guess.
I will test the reference circuit when I get back to the shop but I recall checking it I believe. I'll have to double check to be sure, losing track of all the tests I've done
- RCPro
Thanks for all the help, it's really appreciated. Surely something is gonna prove broken right?
An observation i made when looking all over this engine, it appears as though both cylinder heads have been replaced. The reason I say this is because they look very very new. On a SUV with ~70,000 I can't imagaine they would look so differently then the block.
I did replace cylinder #1 fuel injector. It seems as though because of the high pressure fuel system. These injectors are opened with a quick pulse of~64 volts via a ECU driver and then maintained by 12v.
Now when you first start this care the knock sensors go from 64v down to around 7v or so if I remember correctly. Now I had a hunch that maybe the 64v from the injector was grounding to the head, and then transferring to the block and somehow back through the voltage sensor for the knock sensor. Probably a bunch of non-sense but I'm am starting to wonder if I should find a good exorcist for this car's ghost.. Jokes aside it must be some kind of reading fluke, because I happen to have another car (same year, miles, fuel system, ect) I have been comparing it too; it to starts at a knock sensor reading for 60v+ and goes down progressively as the car is ran.
Food for thought. Asked the boss for a break from working on Volkswagen and this is what I get.
RCPro wrote: Asked the boss for a break from working on Volkswagen and this is what I get.
Your boss is just plain MEAN. :lol:
I like the idea of going into the transmission and looking for data that stands out. Trying to think of all the reasons the ECM would shut the engine off with no codes... How about alternator ripple? Or, maybe try running it with the field connector unplugged. Reaching, I know.
New heads? I would have suggested checking grounds, but you already went over that. Timing? You'd think it'd set a code...
- RCPro
Rooted around in the Transmission PID's and may have found something. When the symptom occurs "Shift Solenoid 2" that is normally commanded on when the engine is running, turns off briefly, and when the engine returns to normal operation it is back on. Another PID "Shift Solenoid 2 CKT Status" goes from "Ok" too "Intermediate".
RCPro wrote: Checked for any codes under global setting in my Modis, noting turned up.
I like it! Maybe unplug the trans connector and see if it stays running? If you're lucky, it'll default to 3rd gear or something, and you can even take it for a drive. :silly:
- RCPro
