FIXEDHonda crv 12 ELC Steering doesn't working , loud grounding when turning
  • RR-Auto
  • RR-Auto's Avatar Topic Author
3 years 3 months ago #62119 by RR-Auto
hey mates I need some with Honda crv 2012 Electrical steering doesn't working and steering is so hard, and making , loud grounding when turning ,
I had27-20 / 27-21 fault code which was , angel string input and out put .
and i check i had good can positive and negative in steering angel steering. and done all calibration but it was not make it any better .
just fault code are gone since i clear the, . I could not go for long test drive since the grinding seems so louden to me
but I turned wheel for at least 20 times, and drive abit front and back for almost 30 meter . and fault did not came back yet,
I am aware there is another angel string sensor in the eps motor , but almost so hard to test the pins nead the motor with out taking its motor out,. And I have but I test the power and ground in the motor where almost 3 V in all 3 wirse .
do you have any advice for further diagnosis ?
best regards
STEERING GEAR ASSMBELI HAD BEEN WEARNOUT,
SO HAD TO CHANGE HOLE RACK AND PINIOON
Time to create page: 0.238 seconds
