Negative long term fuel trim causes
- tmauldin
3 years 3 months ago #62061
by tmauldin
Negative long term fuel trim causes was created by tmauldin
1996 Toyota Camry 2.2l auto
No codes.
Was wondering what the possible causes are for negative long term fuel trim besides sensors, fuel pressure regulator, injectors, purge valve, air filter.
No codes.
- Lupe
- Thank you received: 22
3 years 3 months ago #62070
by Lupe
Replied by Lupe on topic Negative long term fuel trim causes
hows your power steering i heard that bad p s switch can pcm throw trims off good luck
- tmauldin
3 years 3 months ago #62072
by tmauldin
Replied by tmauldin on topic Negative long term fuel trim causes
Power steering is fine
- tmauldin
1 year 8 months ago #82743
by tmauldin
Its been a while. Can the topic be revisited
1 year 8 months ago #82796
RICH conditions are caused by either too much fuel, or not enough air. In addition to what you have already listed, an exhaust restriction, a flooded charcoal canister, incorrect fuel/alcohol compensation, and valve timing can all be possibilities.
Are you trying to fix an issue? How negative are your fuel trims?
Since you have no codes, I would guess that it is less than 10%, which is normal and not a problem.
Replied by Chad on topic Negative long term fuel trim causes
Negative fuel trims mean that, without correction, the engine would be running RICH.1996 Toyota Camry 2.2l auto
No codes.
- tmauldin
1 year 8 months ago #82797
by tmauldin
Its negative 25 percent long term with short term oscillating between 3 negative and 3 positive. I figure it's only matter of time before a p0172 gets set. I also noticed intake manifold pressure was .4 psi lower than what it was when fuel trim was in the correct 10 percent range. Vacuum is vibrating excessively from 19.5 to 20 in hg. When before it was 21.5 in hg steady.
