Re:Re:Re:Re:Re:Re:Re:37 year old coil works, new OEM MOPAR won’t
  • mmorris923
  • mmorris923's Avatar Topic Author
3 years 3 months ago #62049 by mmorris923
I’m going to re-do the back-probed coil voltage test with the fuel pump relay pulled. I was told on the Cherokee Forum that would be an apples to apple test as the 1986 coil won’t fire but just crank, which is what the new OEM does. I think it is important to see if the cranking voltage is the same. When tested the other day the new OEM only showed 10.56-10.70 volts cranking, the battery showed 12.65 volts with my power-probe clone. To my untrained mind that seems significant. I’ll post the results.
  • mmorris923
3 years 3 months ago #62050 by mmorris923
6/24/23 Update:
Well, I tried testing the 1986 coil and the new OEM with the fuel pump relay pulled to measure the cranking volts in what was said to be an apple to apple test. The battery measured 12.51 volts with my power probe clone.
1986 coil- cranking only 10.60-10.76 volts
2023 new OEM coil- 10.65-10.80 volts
they are virtually the same with one giant problem, now the 1986 coil will not start the engine—we are dead in the water, up the creek without a paddle, at least the Jeep is in our garage and not stranded somewhere on the highway or on the 12 miles of dirt road to the ranch. Our mechanic is out of town this weekend so I’ll have to wait to see what he suggest next… unless someone has an idea on the forum for me to try.
3 years 3 months ago #62051 by simclardy
You did put the fuel pump fuse back in? Sorry to ask the dumb question but I've done it.
Sent from my SM-G970U using Tapatalk
  • mmorris923
3 years 3 months ago #62052 by mmorris923
As the teacher used to say, "There are no dumb questions" but I did check on that. Sometimes the answer is the obvious, but not this time.
3 years 3 months ago #62053 by simclardy
I would confirm good power and ground/control with a test light while cranking.
  • mmorris923
3 years 3 months ago #62054 by mmorris923
Good suggestions, except I’ll use the Power Probe clone to see the actual voltage, with the fuel pump relay in place now that the 1986 coil doesn’t work. I will compare the 1986 coil and the new OEM. It is my understanding that the test light will glow dimly with less than 12 volts so I think the Power Probe clone will be more accurate than guessing how bright the test light is glowing. Thank you for the suggestion. Since we can not now go to town and attend church, we’ll watch an on-line teaching this Sunday, then I’ll check the voltage. I’ll report back…
3 years 3 months ago #62055 by simclardy
The voltage meter is probably not fast enough. The test light is going to actually load the circuit. If you have a test light it would be preferred.
  • mmorris923
3 years 3 months ago #62062 by mmorris923
I ran the following tests 6/25/23:
Battery showed 12.45 volts on the Power Probe clone.
on the now non-working 1986 coil the OBDII showed a fault code of of P0351 ignition coil A primary/secondary. Read with a basic Autel reader
 with the connector on the the coil and a non-LED test light the lamp back-probed and cranking it was lit to equal brightness as the positive battery post. I also measured the cranking volts with Power Probe clone at 10.57 volts (high measurement). I also has a spark tester between the distributor and coil stud, showed no spark. This coil, the 1986 showed spark two days ago and ran the Jeep fine.
Measurements on the new OEM MOPAR coil, OBDII showed no fault codes on this coil! With the wiring harness connector on the coil back-probed, a non-LED test light cranking also lit to equal brightness to the positive battery post. The cranking volts on the Power Probe showed a high measurement of 10.46 volts. I had the spark tester hooked up between distributor and coil stud, also had no spark.
My uniformed observation and question why is the cranking volts less than 10.5 when the battery shows 12.45? Is this indicative of anything?
3 years 3 months ago #62064 by simclardy
No as someone else explained the starter load will bring the voltage down.
Is the test light blinking? Ar you going from primary 1 to primary 2 or from ground to positive? If you are go from positive to the ground on the coil. This is your control wire. You need to find out if you have a good control.
  • mmorris923
3 years 3 months ago #62077 by mmorris923
I’m not sure if I did what you said, so I’ll explain what I did. I measured the 10.46 cranking volts with a back probed t-pin in the coil connector at pin #1, which according to a graphic on the Cherokee Forum is the from the ASD C2 Relay pin through a fuse to the coil. The ASD C2 pin measured 12.39 volts, the vehicles battery read 12.40 volts.
To measure the C2 pin I followed instructions to insert a fine wire in the C2 slot of the relay with the relay then re-inserted and the short length of wire sticking out so I could measure the voltage with a digital meter. I’m not sure if this is following your comment or not, but that’s what I’ done for the measurements I got for the cranking volts on the coil as well as the ASD C2 pin volts.
I’m sure you can tell I’m out of my element on this situation but I’m trying to follow suggestions to understand and hopefully find a solution. I really appreciate every suggestion and instructions as what to do in trying to understand and hopefully find a solution as to why the engine is not running. It did run off the 1986 coil for a total 45 days before it stopped a couple of days ago. That was the original mystery behind this thread why the 1986 coil worked and the OEM MOPAR wouldn’t. Thanks again for your time and ideas.
3 years 3 months ago #62078 by simclardy
So you confirmed you have 12 +/- volts at the coil upon crank. Good. Now the other pin, pin #2 is your ground and it is what turns on and off. When it turns off, that is what causes the massive voltage spike. So now check to see if that is working. The best way in my opinion is to use the test light. Connect the alligator clip to positive and the probe to pin #2. Does it flash while cranking? You need to know if the control circuit is working.
  • mmorris923
3 years 3 months ago #62079 by mmorris923
Okay, I understand your instructions, can’t get back to it until tomorrow. Thank you again, I’ll report back…
  • mmorris923
3 years 3 months ago #62089 by mmorris923
I followed your instructions and the test light did flash/blink with the cranking. Based on your comments that means the control is working. I have no idea what that means though—I’m hoping that is good. Further information, I had to charge the battery yesterday so the batt showed 12.90 volts, nice and strong.
3 years 3 months ago #62091 by simclardy
Yes you have control. Was the test done hooked up to spark plugs and spark tester? Curious what your ohm readings are now on the old coil. I would put the spark tester from secondary to ground. This eliminates the secondary wiring. I'm wondering if you have an intermittent short to ground on the secondary system?
  • mmorris923
3 years 3 months ago #62092 by mmorris923
I didn’t use the spark checker for this, I just back-probed pin#2 and connected the non-LED test light to the positive battery post.. All plug wires and distributor to coil were in the normal position with no spark tester connected. I am not running the 1986 coil at this time. I have the new OEM MOPAR coil on the Jeep. I did re-check the primary and secondary resistance on the 1986 coil it is: the primary resistance is, 1.0 ohm and the secondary is 12.23 K ohms on both pins. I checked it because I wondered when the 1986 coil stopped firing the engine I wondered if the coil experienced a change, these are essentially the same numbers, my first readings were the same on the primary but the secondary was 12.29 K ohms, so there was a very minor difference. My graphic charts lists the spec for non-OEM as: .8-1.5 ohms for primary and 9.5-17.5 K ohms for the secondary.
The new OEM MOPAR coil has 1.0 ohm on the primary and 13.21 K ohms on the secondary, reads the same on both pins.The graphic I have on primary/secondary resistance testing states that the OEM specs should be .95-1.20 ohms and the secondary 11.3-15.3 K ohms.
I am not following what you mean about testing from the secondary to ground. Can you spell out in detail what you are recommending? Thank you for your time and patience.
3 years 3 months ago #62101 by simclardy
So your input voltage and control are good. Now we need to find out if the secondary is good. We don't want to test your distributor and spark plugs and everything in between. We just want to test the coil. So I would connect the spark tester to the secondary output and a good ground. This eliminated all the other stuff.
If the tester flashes, do the test, but now with the tester in line with the destitute, does it flash? If yes, but the engine still will not run I would suspect something grounding, if it does not flash I would suspect an open or break.
I wish there was a better way to communicate. You will find the problem, it's not magic.
Ps depending on the spark tester it might not load the coil enough to simulate a spark plug firing under pressure. So I like to take my non led test light and clip one end to ground and put the probe to the high voltage cable or coil, then while it is cranking I will draw the probe out to see how big I can get the spark to jump. Carefull not to run the coil with nowhere for the spark to jump as it will jump internally and cause damage. Obviously if you can't pull a good half inch spark your coil is already shot.
Pps. This last test i learned from scanner danner, he has some good videos demonstrating this test.
  • mmorris923
3 years 3 months ago #62102 by mmorris923
I’m trying to understand how to do your suggested test. I’m not clear on how to actually do what you’re recommending. This seems beyond the edge of my comfort zone. Our mechanics father is very knowledgeable, he worked for a Chrysler dealer when they owned Jeep and would understand the procedure you’re recommending. The issue is he won’t be able to come to the ranch for another couple weeks. I don’t want to make a mistake and cause more problems when dealing the electronics.
I’m going to forward the link to this Forum, I’m hoping this will stimulate his thinking. Due to my lack of background knowledge, I need fairly detailed instructions to preform procedures. I’m no mechanic, prior to this problem my involvement was change the oil and spark plugs things like that. I’ve been learning a lot but I also know my limitations. I’m a retired pastor who is more comfortable swinging a hammer, building a home than turning a wrench on a car. I can’t begin to express how much I appreciate you suggestions and everyone’s willingness to help.
3 years 3 months ago #62103 by simclardy
Fair enough.
3 years 3 months ago #62104 by ferris48
I don't mean to nag but testing for control is not enough. Given the vehicle history and past issues with the harness and connector repair I think a test light connected to ground, connected to the control wire as close to the computer is worth another look.
Figure A.
Test light to battery positive on the control wire, only tests the coil driver in the computer.
Imagine if the fuse is blown, or the positive wire's cut, or the coil is open circuit. A test light to battery positive on the control wire will still flicker.
Figure B.
Test light to ground on the control wire, tests both the control and the battery feed through the coil primary.
When the computer grounds the control wire, the test light is connected to two grounds and the test light is off. When the computer releases the ground, the test light gets a positive, coming through a 1 ohm primary coil winding (low resistance, not dropping much voltage and lots of voltage left for the test light to function), and the test light turns on. The on/off of the test light suggests a working coil driver in the computer and a good power coming from the ASD relay through a fuse, through the coil connector, the coil primary and out the same connector and to the test light.
Since the voltage is only passing through a 1 ohm coil, the test light should be very bright, almost indistinguishable in brightness compared to a test light connected directly to the battery.
3 years 3 months ago - 3 years 3 months ago #62107 by simclardy
I like it. Better yet, put it in series (edit, I meant to say parallel) with the coil and now you are testing the actual circuit. The fact that he had consistent operation with the old coil was leading me to some other problem but your right, you have to confirm the basics before moving on.
Last edit: 3 years 3 months ago by simclardy.
Time to create page: 0.345 seconds
