Hyundai GDI no start. At my limit.
- Knuckledragger63
- Thank you received: 2
3 years 4 months ago #61871
by Knuckledragger63
Hyundai GDI no start. At my limit. was created by Knuckledragger63
This is a 2015 Santa Fe with a 3.3 GDI engine that was towed in. I have good compression, good spark, injector pulse (via scope), good primary fuel pressure. Secondary fuel pressure never gets up to desired according to scan data. Rail pressure sensor voltage matches scan data when tested. won't hit on starting fluid, i can hear burbling noise in intake hose like its lean or out of time but with good compression and scoping cam and crank signals it doesn't seem to be a timing issue. I have been through this thing over and over and can't figure it out! Any ideas before I dump my tool cart and just start mowing yards and selling night crawlers???
- Thank you received: 1139
3 years 4 months ago #61879
Replied by Noah on topic Hyundai GDI no start. At my limit.
What is the compression for all cylinders? What is actual fuel pressure? What is desired fuel pressure? Did it stop running on the customer or did they come out to a no start one day?
I would probably at this point inspect the plugs to seen if they're super fouled beyond the ability to start the car, and take a fuel sample to make sure it didn't get a jug of 2 cycle or diesel out of some ones shed.
- Knuckledragger63
3 years 4 months ago #61904
by Knuckledragger63
Replied by Knuckledragger63 on topic Hyundai GDI no start. At my limit.
compression on all cylinders is 85-95 on first puff and maxes out at 190-210. The plugs always come out of the cylinders with a wet greasy coating on them. I pumped all of the fuel out of the tank I could today and refilled with fresh gasoline. Still no change. I did manage to get the fuel rail pressure to go above the actual by cranking the engine in short bursts (1-2 seconds with about 2 seconds key off in between) Still no start. I will update tomorrow. This alligator is eating me!
- Knuckledragger63
3 years 4 months ago #61939
by Knuckledragger63
This car has spark, injector drive, compression, and no fault codes. I have drained the gas tank and put 5 gallons of good fuel in it and it still won't start. It won't even hit on starting fluid. That, along with the fact that it is rumbling back through the intake is making me think that there is a mechanical timing issue with this engine. (It's a used engine from a salvage yard) Cam a multicam engine still show good compression even though the cams are out of time? I did a scope capture for the intake cam position sensors vs crank sensor and without a known good, they look ok to me. Cranking compression is 85 psi on the first puff at the lowest and maxes out at 210 after about 6 puffs. i don't know what im not seeing here.
- Knuckledragger63
3 years 4 months ago #61940
by Knuckledragger63
By the way, Mitchell Pro Demand has almost no information on this system as far as how the computer strategy works. It would be nice to know what kind of desired vs actual fuel rail pressure this system is looking for during cranking. I like to know how a system is supposed to work before I try to diagnose it.
- Paul P.
- Thank you received: 195
3 years 4 months ago - 3 years 4 months ago #61941
by Paul P.
Never stop Learning.
Replied by Paul P. on topic Hyundai GDI no start. At my limit.
Last edit: 3 years 4 months ago by Paul P..
