2013 Silverado 5.3 cylinders 1&2 misfire at idle flex fuel
- Magshooter300
3 years 4 months ago #61660
by Magshooter300
2013 Silverado 5.3 cylinders 1&2 misfire at idle flex fuel was created by Magshooter300
Cylinders 1&2 misfire at idle / low rpm misfires less or not at all around 1500-1800 rpm.
swapped injectors , coils , plugs and wires.
St fuel trim 7-9 Lt fuel trim 18-19 both banks.
P0172 & P0175 P219 A and B codes are permanent
No misfire codes.
Alcohol content 1%
Any ideas ?
Thanks......Sarge
No misfire codes.
Alcohol content 1%
Any ideas ?
Thanks......Sarge
- Donut
- Thank you received: 11
3 years 4 months ago #61664
by Donut
"Don't ever say 'easy' until the check clears."
Replied by Donut on topic 2013 Silverado 5.3 cylinders 1&2 misfire at idle flex fuel
How do your compression numbers, cranking and running, look?
3 years 4 months ago #61665
Replied by Tyler on topic 2013 Silverado 5.3 cylinders 1&2 misfire at idle flex fuel
High fuel trims on both banks... Do the trims improve off idle? Or as the engine warms up?
If they do improve, smoke the intake for a leak. If they don't improve, look towards a lack of fuel delivery. Dirty MAF, fuel pressure, like that.
Speaking of fuel, has anyone taken a fuel sample yet? I'd be interested to know if there's E85 in the tank, or some mixture of E85/E15. I know the ethanol content is shown at 1%, but that doesn't make it true. P0172/P0175 suggests someone was fighting an ethanol issue at some point.
- Magshooter300
3 years 4 months ago #61668
by Magshooter300
Replied by Magshooter300 on topic 2013 Silverado 5.3 cylinders 1&2 misfire at idle flex fuel
Not sure of compression numbers ,I will check them this weekend. I suspect they will be intermittent also.
- Magshooter300
3 years 4 months ago #61669
by Magshooter300
Fuel trims stay the same after engine hits run temp. Should have mentioned that I did smoke test entire system is tight. Swaped out MAF sensor with several including brand new OEM. Fuel pressure checks out fine. Never used E85/E15. I’m the only owner and never fought this problem before. I should also mention that this is an AFM engine. Thanks again Sarge
Time to create page: 0.254 seconds
