98 c2500 Fuseable link locations
  • Stilts
  • Stilts's Avatar Topic Author
3 years 4 months ago #61617 by Stilts
98 c2500 Fuseable link locations was created by Stilts
Not coming up with Fuseable link 5.7 c2500 previously owned by a bored retired carpenter. He may have replaced it with wood.
3 years 4 months ago #61692 by 70monte
Replied by 70monte on topic 98 c2500 Fuseable link locations
Fusable link for what circuit?
  • Stilts
3 years 4 months ago #61696 by Stilts
Replied by Stilts on topic 98 c2500 Fuseable link locations
I have no power half the uh fuse block.
3 years 4 months ago #61755 by 70monte
Is this a dual battery system? I show a fusible link from the left hand side auxiliary battery if it has one but not one from the main battery to the UH fuse block.
What side of the UH fuse block is not powered up? Which fuses in this box are dead? Looking at the wiring diagram, the problem is probably going to be inside the fuse block itself and not from a power source coming from outside the block.
3 years 4 months ago #61756 by 70monte
wiring diagram.
  • Stilts
3 years 4 months ago #61758 by Stilts
Single battery system, the fuse block is dead to ign1 ecm1 and egm1 all else is hot.
3 years 4 months ago #61760 by 70monte
The power to those three fuses are coming from your ignition switch off of connector C5 in the run or start position. The ignition switch gets its power to that side of the ignition switch from ignition A fuse 6, a 40 amp fuse in the underhood fuse center. The wire from the fuse to the switch is red.
The wire from the ignition switch to those three fuses is pink and is coming off of a splice(s207) that is located in the I/P harness, 12 cm from steering column harness breakout.
You need to access your ignition switch connector and back probe the pink wire coming out of it to see if it's got power in the run or start position. If not, check the ignition A switch 6 to see if it's blown and if it's not, check the red wire going into the ignition switch to see if the power is making it that far.
  • Stilts
3 years 4 months ago #61762 by Stilts
Thank You Brother, I’ll bend your ear when I know something.
3 years 4 months ago #61763 by 70monte
You are welcome. Hopefully you can get it figured out.
