Chevy 5.3 Misfire
- Ephratah
9 years 4 months ago #10084
by Ephratah
Hitting it with a Hammer is worth $5 knowing where to hit is worth $40
Chevy 5.3 Misfire was created by Ephratah
I have a 09 Chevy Avalanche with 5.3 liter with D.O.D engine have a misfire on cyl #4 and slight lifter noise on bank 2. Have checked compression on cyl. #4 and have 180 pounds when cranking I then did a running compression test with scope and a pressure transducer and looked like it was pulling a vac on that cylinder I then hooked up a manual vac gauge and it is showing a pulsing vac. I think I have a bad D.O.D lifter on that cylinder and will need to remove the heads to inspect the lifters is this any thing you guys have ran into?
9 years 4 months ago #10102
Replied by Tyler on topic Chevy 5.3 Misfire
Hey Ephratah! Definitely sounds like you have a stuck closed intake valve, very likely due to a seized lifter. The only other variables I've run into are cam lobes wiped out by the failed lifter, and leaking VLOM (the solenoid pack in the engine valley that runs the lifters) seals causing lifter failure. I have never seen a VLOM that failed in such a way as to make BOTH lifters on the same cylinder fail.
I'd suggest pulling the bank two valve cover and cranking the engine. If you see one valve stuck closed, then it's either a failed lifter or a completely wiped cam lobe. You're right, head removal will be required to inspect the lifters and cam lobes. If the cam lobes look good, then go for lifters and a VLOM. If you find a wiped lobe, then it may be engine time... These engines also like to burn oil on the DOD cylinders, causing repeat spark plug failure. GM has a TSB they've revised, like, 20 times on this issue. :lol:
- MikeatAllCity
- Thank you received: 3
9 years 4 months ago #10110
by MikeatAllCity
Replied by MikeatAllCity on topic Chevy 5.3 Misfire
I ran into this on a similar year trailblazer with a #6 misfire. It had good compression as well. Running compression showed compression at first and then 0psi there after. We found the lifter had spun in the guide, we ended up replacing all of the lifters and everything associated on that side considering we had to remove the cylinder head! I think your next step is to pull the valve cover and see whats going on visually, then sell the tear down!
- Ephratah
9 years 4 months ago #10230
by Ephratah
Replied by Ephratah on topic Chevy 5.3 Misfire
Customer has opted to not have the heads removed and is going to look for a different engine. I do not think that they oil changes have been kept up on this vehicle and I am not wanting to open a can of worms here I am afraid that if I pull it down there is going to issues with the cam and DOD solenoids.
9 years 4 months ago #10263
Yeah, if there's poor maintenance history, then it's probably for the best.
These engines are NOT one of GM's better designs, IMO.
