Chrysler electronic ignition help
  • 65d100
  • 65d100's Avatar Topic Author
3 years 4 months ago - 3 years 4 months ago #61558 by 65d100
Chrysler electronic ignition help was created by 65d100
Back story: Slant 6, electronic ignition. Ran great, but not charging. I was doing some testing, and ran the ignition side of the voltage regulator directly back to battery positive, not ignition + (start). Not sure if that was the right thing to do. It started charging at 13.1 volts. I revved the engine up and it spiked the voltage, and the truck died. I tried to restart it, no luck. I damaged something. That's when the troubleshooting started. Some things are checking out, however there are a few things I need help with.
With ignition in run position, 4/5 pin connector not plugged in at module, I get 12v on both inputs of ballist resistor, and 8v (run) and 12v (bypass) on output. Once I plug in the connector, the input values change for the run circuit. I get .5v on the input, and 3.5v on the output, which feeds the positive side of the coil. Is this correct? I ask because, when I ground the male pickup wire on the harness side, I get no spark. Thoughts? I can give all numbers for my findings, just not sure which are needed. Feel free to ask, and I appreciate the help.
Last edit: 3 years 4 months ago by 65d100.
  • 65d100
3 years 4 months ago #61571 by 65d100
Replied by 65d100 on topic Chrysler electronic ignition help
I was able to get everything sorted out. Basically, the ICM was dead, on the IGN run side of things. I replaced it and all is good now.
Time to create page: 0.243 seconds
