2002 trailblazer OBD2 Port
- jsjj4x4
- Thank you received: 3
3 years 5 months ago #61435
by jsjj4x4
2002 trailblazer OBD2 Port was created by jsjj4x4
1st Question is when you put your OBD2 reader into the port and you get nothing I'm thinking "Is there a fuse that goes to that?"
Between 2 different kinds of readers I got nothing. 1 that runs off bluetooth and an app . The little blue light doesn't flash on the reader
and the app can't find and pair up with it . the other 1 plugs into the port and with or without the key on or car running doesn't do anything
BUT I did try both on another vehicle and they worked. So I don't know if its a fuse or relay or both. I broke the prongy deal on my multimeter
and a nail won't replace it.
NEVER WASH your car ! That's all I did and when I was done I hopped in the car went to turn the key and got a smooth turn and no response.
I turned the key to take it out and it was locked in , like it does when the battery is dead. Luckily I have plenty of things to poke the button and
get keys. After getting them out I put them in to try and start the car. My car started . Now I'm trying to drive down the street but my car was
driving like the emergency brake was on . I was pressing on the gas but barely moving and my check engine light is on. All this because I gave it a bath and powdered it's butt. I don't have a clue where to start until I can get a code. Is there anyone out there , again, that can tell me the name of the fuse to
look at or anything ? Please?
- ferris48
- Thank you received: 47
3 years 5 months ago #61436
by ferris48
Replied by ferris48 on topic 2002 trailblazer OBD2 Port
- jsjj4x4
3 years 5 months ago #61442
by jsjj4x4
Replied by jsjj4x4 on topic 2002 trailblazer OBD2 Port
Well I tell you . This forum has never let me down . Thanks for the reply.
I'm surprised you were able to choose from all the copies that were published. I was so embarrassed and I tried to delete and have just one but it wouldnt let me.
But now that I have the codes I gotta look them up thats going to be fun. Thanks again
- jsjj4x4
3 years 5 months ago #61452
by jsjj4x4
Maybe you can answer this. Now that I got the codes I need to check some fuses. Now I have a parasitic draw so that will alter any readings , correct? While I am checking the fuses is it ok to have the charger on at the same time?
Time to create page: 0.259 seconds
