2006 Jeep liberty 3.6l rough idle.
  • Teranluis1991
  • Teranluis1991's Avatar Topic Author
3 years 5 months ago #61350 by Teranluis1991
2006 Jeep liberty 3.6l rough idle. was created by Teranluis1991
Have one kicking our ass. 2006 Jeep Liberty 3.7l 115k miles. Came in with blown head gaskets and a cracked cylinder head on the pass side due to a leaking water pump. Symptoms were rough idle and misfire codes. The pass side head was replaced with a used one after sending both heads to a machine shop to be redone. After repairing the head gasket job the vehicle came back 3 weeks later with misfire codes and a rough idle. The misfire counter shows some misfires on bank 1 only during development and only feels rough at idle. Compression okay on all cylinders (over 200psi) leakdown test showed acceptable readings about 5-8%. Swapped injectors from Bank to bank with no change, new spark plugs, swapped coils, fuel trims okay on both banks, cleaned throttle body and IAC, performed crank relearn and last but not least replaced the timing system (timing issue was suspected and did find the tensioners clogged with debris). Still, engine runs rough at idle and although no codes have popped up, it's probably only a matter of time. Anyone have any suggestions or ideas on what we could check next?
3 years 5 months ago #61354 by Paul P.
Replied by Paul P. on topic 2006 Jeep liberty 3.6l rough idle.
After all that work I would want to verify cam timing and valve activity. I can't remember but is only the one bank Cams monitored?
Cranking Intake and Exhaust with a Pulse sensor and an ignition sync would be a quick check for any valvetrain anomalies.
Here is a known good:
If memory serves me correct that motor was prone to misfires on bank 1 after a cold startup due to aeration in the fuel rail, but that does clear up.
There is a TSB for lifter keepers.
Never stop Learning.
3 years 5 months ago #61356 by Tyler
Replied by Tyler on topic 2006 Jeep liberty 3.6l rough idle.
Which misfire codes did you find, specifically?
If you use the 'Which Cylinder Is Misfiring' function in the scan tool, which cylinders are counting up? Are there any misfire counts stored in Mode $06?
I know you've done compression and leak down testing, but my first instinct is to suspect a leaking valve. I've had more than one 3.7L fool me in the past. If you did your first round of leak town testing with the tester set at 100 PSI, I'd do it again with the tester at 40 PSI. The lower pressure can actually expose a leak, whereas the higher pressure can inadvertently seal it.
3 years 5 months ago #61359 by Paul P.
How does the cranking cadence of the motor sound?
3 years 5 months ago #61360 by Cheryl
Replied by Cheryl on topic 2006 Jeep liberty 3.6l rough idle.
Intake plenum gasket Leaking? Vacuum leaks don’t show up really in fuel trim on map sensor engines. Does desired and actual idle agree? How’s engine vacuum look? Over 200 psi on compression sounds high like a partial stuck closed exhaust valve
3 years 5 months ago #61368 by lvkeith
Replied by lvkeith on topic Re:2006 Jeep liberty 3.6l rough idle.
If it's possible try to do an in cylinder running compression test. It's what helped me find a broken valve spring that was still holding on to dear life resulting in intermittent misfires on a Buick. Compression was good, leak down was good exhaust valve spring was broken.
Time to create page: 0.252 seconds
