2016 Ford Transit connect
  • Andre3wap
  • Andre3wap's Avatar Topic Author
3 years 5 months ago #61313 by Andre3wap
2016 Ford Transit connect was created by Andre3wap
Greetings everyone,
I am dealing with a no crank issue on my transit van.
Situation:
I Bought a 2016 ford transit connect XLT 2.5L that got hit in the front. I stripped it down to identify any wire that might have been damaged, in addition to replacing the headlights.. radiator etc. The impact did not touch the engine itself. The fuse box however was broken, but no wire visibly damaged.
Issue
After confirming all wiring are visibly good. I installed a brand new battery and everything lights up on the dash, but when I try to start the van it doesnt crank.. I do hear the fuel pump powering up but not even a sound from the starter side.
I checked the 2 relays (F13 30amp and R10?) and they look fine. Any other suggestions? Also, does anyone have the starter diagram can share with me please? so I can attempt to trace the issue. I saw a writeup on here for a regular transit, but wasn't sure if it differs from mine.
Thanks in advance
3 years 5 months ago #61317 by Chad
Replied by Chad on topic 2016 Ford Transit connect
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Andre3wap
3 years 5 months ago #61318 by Andre3wap
Replied by Andre3wap on topic 2016 Ford Transit connect
not seeing your reply. all I am seeing are a bunch of symbols etc. Thanks
3 years 5 months ago #61322 by Chad
  • Andre3wap
3 years 5 months ago #61344 by Andre3wap
Ok got it.
I tried reading the diagram to see how things flow but having a hard time figuring out where to start checking. If you dont mind, please can you give me a quick run through of the fuse/relay I would check to trace where in the sequence if events the disconnect might be?
PS* I bought a brand new starter so I know that's not the issue.
