ENGINE COOLANT TEMP SENSOR
9 years 4 months ago #9850 by MART
ENGINE COOLANT TEMP SENSOR was created by MART
HI, WHEN I JUMP BOTH PINS TOGETHER ON THE ECT THERE NO RESPONSE ON THE SCAN TOOL ALTHOUGH AT ONE STAGE IT SEEMED TO GO TO -40 DEGREES. WHEN I GROUND THE 5V REF ELSEWERE THERES A RESPONSE, IT GOES TO MAX TEMPRETURE BUT INTERMITTENTLY, COULD BE WERE ITS GROUNDED?. THERES 4.87 VOLTS ON THE SIGNAL WIRE UNPLUGGED AND READS 0V ON THE GROUND WIRE. IM NOT SURE WHATS HAPPENING HERE COULD YOU SHED ANY LIGHT ON THIS ISSUE, THANKS.
9 years 4 months ago #9855 by Ben
Replied by Ben on topic Re:ENGINE COOLANT TEMP SENSOR
Year make model and engine size
9 years 4 months ago #9873 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic ENGINE COOLANT TEMP SENSOR
Generally if a PCM detects a value from a temperature thermistor outside the expected range it will simply ignore the sensor and use a substitute value.
9 years 4 months ago #9875 by matt.white
Replied by matt.white on topic Re:ENGINE COOLANT TEMP SENSOR
Little side story. Had a commodore in yesterday, same motor as a US 3.8 Buick, that had a coolant temp sensor code. I recently bought a test lead kit that has two variable resistors in it so thought I'd have a little play.
If I moved the resistor slowly I could cycle the temp reading from cold high idle to high temp and make the cooling fans run. But if I moved the resistor too quick the ecu flagged the signal as implausible and set scan data to 53C and ran the fans continuously. Even if I unplugged my resistor scan data stayed the same.
My point is if you have a code and the data seems a little bit suspicious I'd ignore it.
