no power
  • willie55
  • willie55's Avatar Topic Author
9 years 4 months ago #9800 by willie55
no power was created by willie55
hello i have a 2001 dodge caravan 3.3 this van is in limp mode there is no power going to the eatx relay i used a test light to try to get the relay to open but it didn't doing any thing checked the wires form none broke can you please help me? thinks
9 years 4 months ago #9813 by Chad
Replied by Chad on topic no power
Check fuse #15 (20 amp) in the Inteligent Power Module.
  • willie55
9 years 4 months ago - 9 years 4 months ago #9820 by willie55
Replied by willie55 on topic no power
ok
Last edit: 9 years 4 months ago by willie55.
  • willie55
9 years 4 months ago #9823 by willie55
yes i checked the fuse it has power on it but no power is going to the relay pins 86 and 30 there is power on 87 but not on the rest.
9 years 4 months ago - 9 years 4 months ago #9837 by Chad
For your viewing pleasure.
Last edit: 9 years 4 months ago by Chad.
9 years 4 months ago - 9 years 4 months ago #9838 by Chad
Are you sure it is power on 87? Looking at the schematics, if fuse 15 has power, then relay terminal 30 should have power. I think that your relay is backwards. Not that it matters. It will work both ways. Just trying to clarify pin identification.
  • willie55
9 years 4 months ago #9845 by willie55
fuse 15 has power but 30 on the relay does not have power only one pin has power that is 87
