BMW x5 2007 N52 engine pre-cat sensor
  • naros812000
  • naros812000's Avatar Topic Author
3 years 6 months ago - 3 years 6 months ago #60933 by naros812000
BMW x5 2007 N52 engine pre-cat sensor was created by naros812000
Hello MatesI have attached a picture of BMW N52 engine pre-catalyst sensor which has a potentiometer inside the socket. Can anyone teach me what is this used for?Thank
Last edit: 3 years 6 months ago by naros812000.
3 years 6 months ago - 3 years 6 months ago #60960 by Tyler
Replied by Tyler on topic BMW x5 2007 N52 engine pre-cat sensor
Hey naros812000! I moved your thread to the Repair section.
If I had to guess, I'd say that's a trim resistor. It's used by the ECM and the sensor supplier to account for manufacturing tolerances in the sensor itself. The ECM has a circuit dedicated to reading the resistance value.
Other OEM's put the resistor in different locations, like this Honda sensor:
Last edit: 3 years 6 months ago by Tyler.
  • naros812000
3 years 6 months ago #60963 by naros812000
Replied by naros812000 on topic BMW x5 2007 N52 engine pre-cat sensor
Thank you very much Tyler.
My sensor picture is not like that. I have already re-attached the picture. It is exactly like a volume button that can be adjusted with a screw driver.
Thank you again
3 years 6 months ago #60965 by George Uk
Replied by George Uk on topic BMW x5 2007 N52 engine pre-cat sensor
As Tyler said it is set at the factory for calibration purposes and SEALED. Not designed to be messed with.
However, given the right information you may be able to check that it is still within spec, perhaps adjust it ??
I'm wondering why you removed the sensor in the first place - what were the reasons / symptoms in the vehicle ?
Time to create page: 0.266 seconds
