corvette 1995 fuel pump cutoff switch.
- Inge Jeppesen
- Ford master tech.
- Thank you received: 3
- ScannerDanner
- Administrator
- Thank you received: 500
Don't be a parts changer!
- Inge Jeppesen
- Ford master tech.
I asked him if they had looked for the inertia switch, but it did not sound like they knew what it was.
They had begun chasing the wires for opens.....
So I told him I would try to look up were it could be located.
- ScannerDanner
- Administrator
Inge Jeppesen wrote: A friend of mine was on a vacation trip. His car stalled after driving over a dump in the road. He got it towed to a garage and they said his fuel pump was not running. No voltage at the pump.
My fault, I thought you were talking about the oil pressure switch that has a fuel pump bypass switch in it.
GM does not use inertia switches, my fault.
- Inge Jeppesen
- Ford master tech.
Keep up your great work and all you do.
You reach out and share all your knowledge in a way I have never ever seen before. Rosedale are lucky to have a teacher of your caliber.
- Inge Jeppesen
- Ford master tech.
Corvette c4 5.7 litre.
Vin. 1G1YY32PXS5108826
- Thank you received: 1138
Attachment not found
- JoesAutoElectric
"The man who says it cannot be done should not interrupt the man doing it."
