U Codes and dash warning lights on , CAN BUS
- DamianJP
3 years 7 months ago #60747
by DamianJP
U Codes and dash warning lights on , CAN BUS was created by DamianJP
Hello all, Thank you for these forums. Ive been scanning them lately and its been helping me get this far.
Car is 2013 Chrysler 200. Trying to keep my neighbor from having to go into a shop.
Codes are...
U0141- IPM lost comms
U110C- PCM no fuel level bus signal
U1403- Implausible fuel level
U1120- PCM no speed signal from antilock brake module
U0100- Lost comms with ECM/PCM "A"
U110A- PCM lost comms with SCCM (Steering Colum Control Module)
U1110- No speed signal from antilock brake module
U110E- Ambient air temp signal to BCM/PCM is lost. CAN "C"
Stored codes only have 4 of those 8 codes above.
Pending and Permanent have all 8 codes above.
Starts and drives around the block fine. Sits and idles fine. But the dash panel has weird things going on. Most of the warning lights are lit and sometimes there are squares around each shift icon (PRND31).
Parasitic draw was found and fixed but the battery/system saw some low to zero volts until it was fixed. Also system was jumped or charged thru the cig light port at one time. Just wanted to bring it up incase it corrupted the program in the PCM or whatever. So far battery is around 12.4-12.6 and alternator is outputing 14.2 to 14.7 charging. Battery connections are clean and good.
Also drivers window up and down button is broke. One headlight bulb is out aswell. Blend door accuator is clicking. Bringing all that up in case it ties in to the U codes or CAN BUS aswell.
Was thinking TIPM , PCM or grounded/shorted CAN BUS wiring.
Checked CAN BUS thru OBD2 and everything checks out. Only thing is sometimes the CAN BUS voltage is DOMINATE (CAN low 2v - CAN high 3v) and sometimes RECESSIVE (CAN low 2.5v - CAN high 2.5v). Ohms read 60ohm. Power and ground pins check out too on OBD2.
Does the CAN BUS wiring test I did mean the integrity of the CAN BUS comms wiring good?
Is this down to a TIPM , PCM or other module/connector screwing the CAN BUS comms up?
What should be my next maneuver ?
I know its a chunk of stuff to go through but Im trying to give you guys all the recon I have. Please let me know if you have any other question that will assist in fixing it. First time learning about U codes and diagnosing CAN BUS issues.
Thank you for your time and help,
DamianJP
Codes are...
DamianJP
- Cheryl
- Thank you received: 215
3 years 7 months ago - 3 years 7 months ago #60749
by Cheryl
Replied by Cheryl on topic U Codes and dash warning lights on , CAN BUS
What modules can you communicate with the scanner? Also I don’t think you can check the pins 6 and 14 at the dlc as those go to the tipm if I remember correctly which is the gateway module. I’d focus on reading abs scan data lookin at the vehicle speed sensor also do you get a no bus message on the cluster??
Last edit: 3 years 7 months ago by Cheryl.
The following user(s) said Thank You: DamianJP
- DamianJP
3 years 7 months ago - 3 years 7 months ago #60750
by DamianJP
Replied by DamianJP on topic U Codes and dash warning lights on , CAN BUS
Thank you , Cheryl. Sorry for other 6 posts I dont know how that happened nor can I delete.
I have a Autel MS609 scanner and a good multimeter, thats it. Pretty privative , I know. I dont have one that shows the modules on a network. Im trying to do as much as i can before sending to him a shop.
Is there away to flip the TIPM over and do the same test I did at the DLC to get a true reading of CAN BUS wiring?
I dont know if I can do the ABS / VSS test with what I have. What made you think of the ABS/VSS? Im curious and love learning.
EDIT : I have NO "No BUS" message on cluster
Thank you !!
DamianJP
Thank you !!
DamianJP
Last edit: 3 years 7 months ago by DamianJP. Reason: question
- Cheryl
3 years 7 months ago - 3 years 7 months ago #60754
by Cheryl
So no bus is on cluster? I’ll look at a network diagram tomorrow. You may need to start unhooking modules one at a time. I’d start with the abs then pcm. Cycle key each time from on to off see if no bud goes away. Do system scan on all modules and let me know which ones you can communicate with
- DamianJP
3 years 7 months ago #60762
by DamianJP
There is not a error on the dash thats says "no bus". Sorry for the mis communication on my part.
Went to scan car's ABS with the MS609 and it said no link to ABS.
Said to check...
1)Cable connection on dlc
2)Ignition on
3)Battery condition
All seem to check out...
Maybe my scanner is too old? Limp the car up to parts store for better scan with better scanner? Or is no link to ABS a clue to what is going on?
Rest of OBD2 codes read. Live data all work. Really was interested in seeing what the ABS feature of this scanner was going to say.
All in all ive been learning alot, active vs passive abs sensors , tone rings and checking can bus with multimeter ect. Just want to see dude happy and not get hosed if I cant fix it for free.
Thank you for your time/help/info.
DamianJP
Said to check...
2)Ignition on
3)Battery condition
DamianJP
- Cheryl
3 years 7 months ago #60764
by Cheryl
If your scanner can’t talk to the abs module and the parts store scanner can’t talk to the abs module then you need to check powers grounds and communication lines to the abs module. If there good the abs module is junk
