2003 Dodge Dakota 3.9 PO351, backfire low power
- rpd1125
- Thank you received: 10
3 years 6 months ago #60729
by rpd1125
2003 Dodge Dakota 3.9 PO351, backfire low power was created by rpd1125
Good fuel pressure. Distributor Sync set to 0
Attached is the cam and Crank current waveform.
Crankshaft position sensor was replaced due to customer damage of old crank sensor when customer installed their own clutch
Problem started after clutch installation
Po351 keeps coming back on when you got wide open throttle every single time
Also replaced the ignition coil attached is screen shot of ign primary waveform measured at control,side of the ign coil
And the Cam and Crank signal waveform. Yellow channel is Crk green Channel is Cam
This vehicle has absolutely no power when you throttle
Ign wires are in right location per firing order.
Back pressure test doesn’t show clogged exhaust either. O2 sensors respond to rich and lean induced conditions too.
Any input would be appreciated
- Cheryl
- Thank you received: 215
3 years 6 months ago #60732
by Cheryl
Replied by Cheryl on topic 2003 Dodge Dakota 3.9 PO351, backfire low power
I’m not good at looking at ignition waveforms but the firing looks kinda funny. But have you checked how far of a gap the spark can jump with a spark tester while running?? Could be weak spark
- rpd1125
3 years 6 months ago #60733
by rpd1125
Replied by rpd1125 on topic 2003 Dodge Dakota 3.9 PO351, backfire low power
Spark is plenty strong. Camera just caught at odd time when engine was being shut off. Otherwise raster pattern looks good
- Cheryl
3 years 6 months ago #60740
by Cheryl
Have you gotten a known good cam crank relationship to compare to? Have you checked what the o2 sensors do at w.o.t
- rpd1125
3 years 6 months ago #60748
by rpd1125
Yep. Someone here on the forum had a known good waveform on another post. My waveform is same as theirs.
O2 sensors are fully responsive. And if I lean or Rich the mixture they respond as well
