Wiper Diagnosis
  • Richard6767
  • Richard6767's Avatar Topic Author
3 years 6 months ago - 3 years 6 months ago #60644 by Richard6767
2002 GMC SIERRA Wiper Diagnosis was created by Richard6767
Wiper works only on high and doesn't reset to home when shut off. My thought is to check switch and/or relay before jumping to wiper motor. Am I on the right track?
Last edit: 3 years 6 months ago by Richard6767. Reason: Adding vehicle to the subject
3 years 6 months ago #60647 by juergen.scholl
Replied by juergen.scholl on topic Wiper Diagnosis
Which car, which system.
Looking at a wiring diagram and knowing how this system is ment to work will give you a headstart.
Motor itself when working on hi speed is not suspicious to begin with.
  • Richard6767
3 years 6 months ago #60650 by Richard6767
Replied by Richard6767 on topic Wiper Diagnosis
2002 GMC SIERRA
3 years 6 months ago - 3 years 6 months ago #60651 by juergen.scholl
Oops, see below :silly:
Last edit: 3 years 6 months ago by juergen.scholl.
3 years 6 months ago #60653 by juergen.scholl
Do you have access to a scanner that will show command/control signals (actual versus desired for example )to and from the wiper control module?
Otherwise confirm the corresponding voltages to the module: if they are correct the module itself is at fault.
  • Richard6767
3 years 6 months ago #60656 by Richard6767
Unfortunately my Thinkscan Max doesn't have that capability
3 years 6 months ago #60657 by juergen.scholl
Then test with a multimeter directly at the wiper stalk and at the module terminals for the respective voltages depending on the wiper stalk position.
3 years 6 months ago #60659 by Matt T
Replied by Matt T on topic Wiper Diagnosis
Test the switch inputs at the module just to be thorough but I doubt they'd cause loss of low speed and no park. It sounds like a low speed problem inside the wiper module/motor assembly. Not one I'd fire a module at but the cannon would be loaded :silly:
Also the switch contains resistors so you'll sometimes see less than battery voltage on Mux1 & 2 depending on what position the switch is in.
  • Richard6767
3 years 6 months ago #60660 by Richard6767
When I get home I will test this.
  • Richard6767
3 years 6 months ago #60661 by Richard6767
Thank you for this, when I get home I will try this.
Time to create page: 0.417 seconds
