no start 5 volt referance
  • skyline2155
  • skyline2155's Avatar Topic Author
3 years 7 months ago #60553 by skyline2155
no start 5 volt referance was created by skyline2155
hi new here and love your videos i have a 01 ford f250 7.3 diesal powerstroke no start, need to know why i would have 11 volts on both positive and negative of a connector that goes to one of the 5 volt sensors and how to diag the system 5 volt referance i think yhat maybee the connector is shorted out not sure
3 years 7 months ago #60567 by Tyler
Replied by Tyler on topic no start 5 volt referance
To help you with that, we'd need to know which sensor you were testing. Was the sensor plugged in or unplugged? What were the wire colors?
  • skyline2155
3 years 7 months ago #60572 by skyline2155
Replied by skyline2155 on topic no start 5 volt referance
i have tested most of the sensors and the one that stands ouut is the heater/water in fuel sensor it has 11 volts on both sides i dont think this is part of the5 volt referance the wiers are gray/red and red lt green the gray goes to the pcm the other goes to waste gate selenoid then to the ignition and pcm relay this should have 12 volts on the gray wire and 0 on the red greeen wire is that correct or not sensor unpluged
  • skyline2155
3 years 7 months ago - 3 years 7 months ago #60573 by skyline2155
their is also a p0113 code icp sensor voltage high the icp is on the 5 volt circuit and also has a gray red wire i think thid is the signal return wire for the pcm or grouund as the pcm grounds the circuit is this correct
Last edit: 3 years 7 months ago by skyline2155. Reason: more information
3 years 7 months ago #60574 by ontheriver
Replied by ontheriver on topic no start 5 volt referance
You should double-check the description of the code you posted, I get i.a.t., that code and many others could pop up with excessive cranking,(low volts)
  • skyline2155
3 years 7 months ago #60575 by skyline2155
you are correct it is the intake air pressure sensor but it is voltage high not low is that from a short to power
3 years 7 months ago #60576 by ontheriver
That code came up after the no start? If so, it's a low voltage problem. Does this truck crank over right now with the same sound as always? A failing battery or compromised battery cable will cause a bunch of issues. Is this a personal truck? She's getting up there in years, I have a 97' 7.3, love it, so, with that said... There is a die-hard community of these vintage trucks out there, powerstroke.org is one. Not saying that there is anything wrong here on this site, but those guys eat, sleep and live for the 7.3, lol
3 years 7 months ago #60578 by Tyler
I grabbed the wiring diagram for the fuel heater/WIF sensor for reference:
According to this, you should get 12V on both wires at the heater/WIF connector with the key on. The red/light green wire is powered by the PCM relay, and the grey/red is a switch input from WIF. The WIF sensor is a pull down design, so 12V with the heater unplugged (or no water in the fuel) would be normal.
