Cold start
- Herbsauto
3 years 7 months ago #60505
by Herbsauto
Cold start was created by Herbsauto
2010 dodge avenger sxt 2.4 car will not start on its own first try of the day until I hit it with starting fluid then run fine and start back up for a few hours then back to no start cranks fine changed two fuel pumps everything test out ok but fuel is 40psi believe it should be 60psi .what should I do next ????
- paulctownsend
3 years 7 months ago #60514
by paulctownsend
Paul Townsend
Replied by paulctownsend on topic Cold start
COULD BY TO MUCH ALCHOL IN THE FUEL OR JUST POOR FUEL.
Paul Townsend
3 years 7 months ago #60525
Replied by Tyler on topic Cold start
Let the car sit overnight. Before you go to start it again, use a scan tool and compare the Intake Air Temperature and Engine Coolant Temperature sensor readings. They should be within 10 degrees of each other.
If the IAT is reading rationally, but the ECT is skewed, dig more into the ECT circuit.
- MarkBeck101
- Thank you received: 2
3 years 6 months ago #60864
by MarkBeck101
Replied by MarkBeck101 on topic Cold start
Cold start strategy relies on the Engine Coolant Temperature (ECT) Sensor operating properly to provide a function similar to a carburetor choke to richen the fuel mixture at cold start and during warmup.
The equivalent port fuel injection function at cold start is called wall wetting. Which means you have to inject additional fuel into the intake port at start because the injected fuel tends to coat the inside of the port, which is cold, instead of mixing with the air as the intake event occurs.
If the vehicle is equipped with gasoline direct injection (GDI) the fuel adder is very small compared to port injection because the fuel is injected directly into the cylinder. Better cold start control is one of the main reasons for DGI in addition to high pressure fuel atomization and mixing.
For port injection the cold start fuel adder, at freezing temperatures, can be huge in order to start the engine. So much so, that if the engine does not start you will eventually have to use the clear flood function in order to get the engine to start. Yes, if the engine can crank but not achieve engine position sync, or it drops out, fuel injection can flood the engine to the point of being too rich to start. As it turns out effective cold start strategies take a lot of dyno tuning (calibration), in a temperature controlled dyno cell to perfect, with some strategies being surprisingly complicate especially for 4-cylinder engines, which tend to run like crap during a cold start, as compared to an inline 6-cylinder engine for example.
A bad ECT sensor, as diagnosed by the ECM, should be recognized and set the MIL. However, if the sensor output is not open or shorted to ground, and the ECM input circuit is working, it is possible a valid voltage level is present, which would not set a DTC, and could negate the cold start fuel adder and your engine would not start when cold.
Generally, the ECT sensor is a highly reliable device, so if the ECM is not receiving a working signal then the input could be influenced by a short to another circuit or a very high impedance short to ground, any type of short which would put the ECT circuit within working range but still presenting the wrong temperature.
If you go Key On Engine Off first thing in the morning and use a PID capable scan tool for generic OBD-II, the ECT temperature should be very close to the Intake Air Temperature (IAT) sensor. In fact many times the same thermistor element is used for both, and even the input linearization circuit may be identical. The difference in the two being the ECT has a brass body (slow responding) and the IAT has a plastic body (fast responding, as compared to ECT). If the two temperatures are not within 5 degrees C then you have a problem with the ECT circuit, but no necessarily due to a bad sensor.
Time to create page: 0.261 seconds
