2008 Dodge 6.7 Cummins running terrible. Injector driver?
  • kkane97.kane
  • kkane97.kane's Avatar Topic Author
3 years 7 months ago - 3 years 7 months ago #60409 by kkane97.kane
Cummins injector driver testing
2008 6.7 came in no start, customer replaced injectors still same thing.
Fuel rail pressure was erratic, tore back down and redid injector job 3 fuel supply tubes were loose.
Crank it no start, checked cam and crank signals are pcm compared to known good
The only thing I have found is it's running off of low voltage around 25v to the injectors, I believe these are supposed to be 50v piezo injectors. This reminds me of a power stroke 6.0 running with a bad FICM I captured two injector pulses, one when the engine is running smooth and the other when it is plooming white unburnt fuel smoke and barely running
Health report on all modules led to a CAN B - circuit code. Traced that down and repaired pin at TIPM
Now trucks running
It will idle but very rough with little white smoke of unburned fuel - burns your eyes-
Any throttle it completely falls on its face and clouds of white smoke
Unplugged FCA runs at full fuel same condition
Verified 10 psi of fuel pressure from lift pump
Exhaust is open turbo is not stuck in full closed position
Intake is clear
All pcm powers and grounds have been load tested good
All injector circuits from pcm through valve cover harness load tested good
Scoped injector circuits and noticed they are all firing with 22 volts +- a little. Aren't these 50+ v piezo injectors? That low voltage had me concerned as the ground path for the injectors is directly following the voltage curve, I scope a identical known good truck and saw a perfect waveform like id expect.
So I am asking, I'm 99% sure I have weak injector drivers in my computer as I have load test and pin fit checked all my pcm grounds. Anything I may have missed
Last edit: 3 years 7 months ago by kkane97.kane. Reason: Added information
3 years 7 months ago - 3 years 7 months ago #60416 by ginuwine11
I do know the 6.7 liter has IQA (Injector Quantity Adjustment) coded Bosch injectors that need to be programmed. Each fuel injector has a six-digit alphanumeric correction code. The correction code is printed on the intake side of the fuel injector and is used to identify injector calibration. When replacing any fuel injectors, this code must be entered into the vehicles Powertrain Control Module (PCM) using a diagnostic scan tool. If they are not programmed they won’t leave a code but they sometime they will perform erratic. Also any remanufactured non-Bosch injectors you have installed that is not rebuilt thru a certified Bosch process, you have to wonder if they are performing according to Bosch’s standards. I know it’s considerable savings for purchasing remanufactured injectors, but a lot of issues can happen from non-Bosch remanufactured injectors if not thru a certified Bosch process.
Along with verifying the common rail pressures. I read you verified lift pump pressure. You will also need to verify lift pump volume. If that is good, compare in your scan tool “Actual” pressure vs. “Desired” fuel rail pressure, they should be very close. If that is good, you need to verify return fuel volume from injectors, in case of a worn or not seating balls and seats from the injectors. If pressure is not the same, they sell caps to isolate injectors to see if rail pressure comes up, if it does you have found the bad injector. Also you mentioned that you have white smoke, it may be an injector or the cylinder has a low compression that would possibly give the same result of a bad injector. Any chance you get, if you remove any injector again, get a compression test in the injector hole with an adaptor, and verify its cylinder compression. Hope this helps.
Last edit: 3 years 7 months ago by ginuwine11. Reason: More info added
  • kkane97.kane
3 years 7 months ago #60417 by kkane97.kane
Nope no codes, I've ran the truck several times for a couple minutes to see if it would set something but it never did
3 years 7 months ago #60419 by ginuwine11
I edited the first message above, p[lease read.
  • kkane97.kane
3 years 7 months ago #60422 by kkane97.kane
IQA codes have been entered into the pcm, supposedly the truck ran this way prior to the injectors being replaced.
Lift pump pressure was in spec
Volume test came back with 530 ml in 10 seconds.
Injector return test was 45 ml in 30 seconds with rail pressure commanded to maximum under fuel pressure leakage test. All 6 injectors were isolated one at a time and measurement was between 42-48ml across all 6.
Fuel rail pressure desired and actual pressures are within a couple hundred psi, it is hard to go off that as poorly as the truck runs.
I was trying to post this question a couple weeks ago but had issues with a new forum update and could not since then I have learned the following
The customer had a charging system voltage code. He diagnosed that as a faulty pcm. Send the computer out to be "rebuilt" and reinstalled. Still had the charging issue, and the truck ran like crap. He said he had needed injectors for sure before he replaced them for a issue with them returning to much fuel and causing a low rail pressure issue underload. So he replaced them thinking that was why it ran like crap after the PCM was "rebuilt" . When that didn't fix It sat for months and was towed to me. I found the charging code to be a dirty battery terminal.
Did you look at the injector voltage waveforms I posted in the original post? The ground path for the injectors has 25+v on it back proved at the UVC.
Me being confused by that I had a friend stop by with an identical configuration truck and scoped his as well and got the second sample waveform.
I'm at the conclusion that there is something faulty with the new computer. This truck isn't a rush as he doesn't have the money to dump into it for a wrong diagnosis ( also a friend's truck) so I'm trying to do as much research as I can on it before calling a $3500 replacement computer from the dealer
3 years 7 months ago - 3 years 7 months ago #60428 by ginuwine11
The fuel injector should be 50 volts. I would say you do have a power supply issue to the injectors.
  • kkane97.kane
3 years 7 months ago #60429 by kkane97.kane
What year was that from, my second picture I captured looks proper to me that I took from a known good truck. Do you have a waveform of the ground path
3 years 7 months ago #60430 by ginuwine11
That was a 2008 6.7 liter. And no the pic was from another forum I found. I had to remove it due to the watermark on pic from other forum. Are you able to post the current waveform?
3 years 7 months ago #60431 by ginuwine11
This is the current waveform
  • kkane97.kane
3 years 7 months ago #60435 by kkane97.kane
My current clamp was broken when I was looking at the truck a couple weeks ago, I didn't get a current sample.
Do you have any thoughts as to the low voltage I'm seeing? Barking up the wrong tree?
I'm very familiar with the engines and maintain a fleet of 63 of them (UPS) . The typical checks have all passed on this truck
  • kkane97.kane
3 years 7 months ago #60436 by kkane97.kane
To this, as far as how I am reading my injector pulse captures my ground has 25v on it, like the ground path is the issue
3 years 7 months ago - 3 years 7 months ago #60440 by ginuwine11
So is the supplied injector power feed reading 25v if the injector is unplugged at the harness connector? Also unplugged, anyway you can backprobe injector power feed at PCM for any of the injectors for the voltage reading?
  • kkane97.kane
3 years 7 months ago #60441 by kkane97.kane
I did not test with the harness unplugged,
All injector circuit wires were load tested back to pcm
I have been unable to determine which power feed is for the injectors specifically, but all power feeds and grounds were also monitored backprobed while engine was running and no anomalies were found, good grounds solid power feeds
3 years 7 months ago #60442 by ginuwine11
As far as 25V on the ground side, If this is ground side switched, and you don't have the 25V being pulled to ground, then yea I agree PCM is not doing it's thing.
  • kkane97.kane
3 years 7 months ago #60443 by kkane97.kane
They are ground side switches with 50v constant
3 years 7 months ago #60444 by ginuwine11
I wonder if the 6.7 has any strategies in place for the ECM. Not sure that ECM may have shut down the injector driver control side due to a low voltage supply to injectors, not sure. I think I have exhausted all information, it looks as though you have load tested powers and grounds to ECM and all is good.
You can also look up on a scan tool for the PID's, BALRCYL1 – BALRCYL6 Balancing Fuel Flow Rate. They are for each cylinder. It will display a positive or negative number. A "0" ( Is the ideal perfect number) means the ECM is not adding or subtracting any fuel to get the optimum crankshaft rotational velocity (torque). If you see a negative number such as "-1.5", the ECM has decided that cylinder is being over fueled and is now taking fuel away and opposite for a positive number. This will give you some information on how well the injectors are doing and working.
  • kkane97.kane
3 years 6 months ago #60623 by kkane97.kane
Final update, I sourced a used PCM and reflashed the VIN with EFI Live , truck starts and runs perfect no other issues.
Was a bad injector driver internal to the pcm
3 years 6 months ago #60639 by ginuwine11
Good deal, and thanks for posting a followup!
Time to create page: 0.455 seconds
