2014 Nissian CVT tranny swap
  • Ephratah
  • Ephratah's Avatar Topic Author
9 years 5 months ago #9477 by Ephratah
2014 Nissian CVT tranny swap was created by Ephratah
I have a customer with a 2014 Sentra that needs a CVT swapped out he has purchased a low mileage used one and wants me to swap it All Data say to drop motor and tranny out the bottom as a unit then split once it is on the floor. Does any on know if the engine can be left in place and the K frame be lowered and done this way? Also looking to see if any one knows how much fluid I will need to refill it is $16 a quart and dont want to have a lot of extra kicking around at that price.
Hitting it with a Hammer is worth $5 knowing where to hit is worth $40
9 years 5 months ago - 9 years 5 months ago #9484 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2014 Nissian CVT tranny swap
Here be dragons ! A good 2nd hand Nissan Jatco CVT is rarer than golden unicorn dropings. There is a good chance the replacement transmision will be in worse state than the one coming out. A small company down the road from me is contracted to Nissan Uk to produce factory exchange units --- they are working at full capacity.
Last edit: 9 years 5 months ago by Andy.MacFadyen.
9 years 5 months ago - 9 years 5 months ago #9497 by Noah
Replied by Noah on topic 2014 Nissian CVT tranny swap
Same goes for most CVT transmissions. Very rarely do I sell a used CVT trans that doesn't come back before the warrenty is up. Or install one that doesn't require a replacement in short order. I guess they just haven't worked it out yet....
I've never worked on a Sentra that new, but I can't imagine that little car would require such a process, unless the transmission isn't very easily uncoupled from the engine. Maybe it just needs a bit more room to separate than they give you in the car?
AllData says 7.25qts capacity.
Last edit: 9 years 5 months ago by Noah.
9 years 5 months ago #9502 by CurrentDraw
Replied by CurrentDraw on topic 2014 Nissian CVT tranny swap
Do Nissan CVT transmissions require any form of TCM encoding after replacement of trans?
Or is it a simple "plug and play"
9 years 5 months ago #9516 by Tyler
Replied by Tyler on topic 2014 Nissian CVT tranny swap
I don't see why you couldn't leave the engine in the car on this one. Maybe it has to do with engine mount placement on the K-frame?
If it's anything like the other Nissan CVT's I've worked on, you'll need some kind of pressurized bottle to get fluid into the trans after installation. One of those goofy pull-a-plug-to-check-the-level setups. :angry:
Just saw a 2013 Altima with around 70,000 miles and a torque converter clutch codes. These things seem to be made of glass...
The following user(s) said Thank You: Ephratah
9 years 5 months ago #9518 by Andy.MacFadyen
I am not a big fan of Jatco transmissions both the CVT and slushbox, back in the day transmissions like the BW35, Torqueflite, Powerglide and Turbo Hydramatic were pretty well indestructable.
