99 rx300 timing issue
- Madams198623
9 years 5 months ago #9468
by Madams198623
99 rx300 timing issue was created by Madams198623
I got my 99 rx 300 dohc four cam vvti engine it bad a bad exhaust valve so I got all that done cylinder heads back on now I can't figure how the cams go bk in and line up so it will be in time when I took it apart I made sure it was at Tdc on the compression stroke
- Madams198623
9 years 5 months ago #9471
by Madams198623
Replied by Madams198623 on topic 99 rx300 timing issue
It's a 3.0 v6 vvti engine each cam has two dots on one side and 180 degrees from that has one dot so I'm lost on how to put them back lined up so it will be in time please help any Lexus or toyota pros
- matt.white
- Thank you received: 29
9 years 4 months ago #9867
by matt.white
Replied by matt.white on topic Re:99 rx300 timing issue
Did you get this sorted?
- Madams198623
9 years 4 months ago #10013
by Madams198623
Replied by Madams198623 on topic Re:99 rx300 timing issue
No it's my side vehicle and I haven't messed with it in a couple weeks
- Ben
- Thank you received: 215
9 years 4 months ago #10014
by Ben
Replied by Ben on topic Re:99 rx300 timing issue
You just need the timing procedure for it? I'll look it up when I get back to the shop
- Ash03
- Thank you received: 6
9 years 4 months ago #10028
by Ash03
Replied by Ash03 on topic Re:99 rx300 timing issue
Use the firing order to figure out cam lobe position.. that way u can see which marks align
Sent from my SM-G531H using Tapatalk
- Ben
9 years 4 months ago #10042
by Ben
